**DIY WHEEL STUD*** lots of pictures
Hey HT! I have been driving with stripped wheel stud for 4 years. I just now decided to change it and take some pictures and explain how I did it. Feel free to ask any questions or give any advice. This is just a outline of how it is done. You can do it slight differently.
This is the stud we will replace
Started out by wiring the brake caliper onto the upper controll arm and getting out of my way
I took off the brake caliper off to check my brakes and this is what I observed
while screwing back the caliper bolt, it would not be tight and this is what happened
The 2 nuts, that hold the brake disk, would not unscrew so I used a chizzle and forced them out
Once the disk is off this is how it'll look
So I CAREFULLY hammered on the bolt and got it to go back. It only goes out like 1cm. So I grinned off the front of the bolt and then did the flat(rear) part of the bolt.
Once the bolt out, get the hole so it would be away from the metal shield because it will be in the way when getting the new stud in.
The stud DOES NOT go in just like that so this is what you MUST do.
Once the bolt was in, I aligned it and found the teeth that it would go in. Next is pulling in the stud NOT hitting it in. This is how I did it first time but after doing it, I recommend using one big nut that would go over the stud and another nut that is same thread as the stud. Stard pulling the stud till its flat at the rear.
Now all finished
Now all finished
I always see people do it this way,but never worked for me. maybe i was doing something wrong,so I took the whole hub off,not that hard either,just have to take the axle out too.just from the hub,good write up
lol yea it gave off so much rust that I had to look the other way so I dont inhale it. It should be greased up?
What do you think about my caliper rubber thats ripped in the puctures?
You can get them anywhere that sells auto parts.
http://www.autopartswarehouse.com/se...l+stud&submit=
Or get one from a salvage yard.
I tried it this past weekend and it does not work on my 96 EX. You can barely get the broken stud out by cutting it, but the new one will not go in, even with the clip head.
I looked at an assembled DX knuckle that I have, and it definately has more room around the back of the hub plate.
Unfortunately, I think 96-2000 EX owners are out of luck. It was definately worth a try - it sucks to have to buy a new bearing to replace a $2 wheel stud.
I tried to do the "quick" repair when I had two broken studs on the left wheel last year and could not get the new studs in (the old one I could get out), so I had to remove the entire hub and get a shop to remove the old wheel bearing and install a new once since the old bearing was damaged during the process. Just wanted to post this in case anyone is looking on info for this job. I was able to get to the point of removing the hub but had to take the hub to a shop for the bearing removal and installation, which was like $80 IIRC. Other specialty tools can be rented for free.
Meraut
May 21, 2013 07:02 AM
Honda3133
Aug 28, 2011 05:42 PM
