PWJDM EG fog harness help. Yes, I have searched a lot!
If picture doesn't work here is the link to the product. Just click picture to enlarge:
http://passwordjdm.com/PasswordJDM-F...P1320C137.aspx
So I know where everything goes except for the red and white wire on the harness. Also, I don't know what to do with the two connectors that are on the right of the picture (2nd and 3rd from the right). One connector has 2 plugs and the other has 3.
I have tried connecting the red to option #4 and the white to option #2. All it did was burn my fuses and light didn't turn on. I even tried connecting the wires to the extension plug (the plug with 1 output) and plugged it into #4 in the fusebox; it also burned my fuses again.
Any ideas? I have the PWjdm harness with eBay fog lights (eBay harness fried).
Thanks.
I will look at mine in the morning and get some pictures for you. I removed it because I got a OEM harness and switch, but it's still all together.
Red and white plug into the y harness. The single plug from the y harness went into either 2 or 5 on the fuse box(i dont remember)
You should also have a relay and a fuse.
Hope this helps
Hope this helps
541Motorsports
May 12, 2012 02:25 AM
LHDHonda
Oct 18, 2010 07:40 PM
mr. goodwrench
Apr 30, 2007 10:17 AM
