1996 Acura Integra Stock won't blow any air out of vents climate control problem?
I turned my climate control to any number 1 - 4 and I can't get any air to blow out the vents. It just started 2 days ago. I changed out the heater Motor Resistor behind the glove box and this didn't fix the problem. I also tried changing out the blower motor under the glove box with a working one and this didn't fix the problem either. I get no air what so ever guys and its cold outside. Plus no front defrosters sucks. Anyone have any idea if it could be something in the climate control or has ran across this problem before?
See if you have power at the blower motor, blue/white, if not check fuse 37 - 40A, [hot at all times] in engine bay fuse box.
If fuse is good, you will have to check the blower relay, pull the relay and check the relay plug, there will be one 12V constant, [hot at all times, fuse 37] and a 12V switched, [hot when ign. switch is in run position] if no switched 12V check fuse 13 - 7.5A, [hot in run] in under dash fuse box. 94
tx6stringer
Feb 16, 2007 08:07 AM
GapxGuy
Nov 20, 2001 01:00 PM
