1992 sedan wheel adjustment
I'm not shure what the word is in english...
left tire is straight while the right one turns right and I can just feel that it's wrong becouse the steering is terrible.
I need to adjust it so it's straight on both sides, just wondering if it's suppose to be a little bit outwards or a little bit inwards?
just a pic I found on google, not from civic but hoping you get my point.
I know how to adjust it, but I dont know if the wheels are suppose to turn a littlebit out or in on a fwd car.
I believe front toe should be between 0" and -1/16" on both sides. So very little if any toe is optimal. I am guessing you might need that reading in cm, so...
0cm to -.16 cm if my math is correct.
Why not do it myself and safe some money?
i suggest you perform a "shakedown" test on the car first before you go doing any alignments
you may have bad ball joints or tie rod ends or bushings altering your alignment
I've allready altered the alignment and its much better now. I cant find anything wrong with the ball joints or bushings, but the car hasnt been checked yet, there it will get the proper "shakedown" test.
I just needed a temporary fix becouse the tires where getting destroyed way to fast on the inner side. Hope it stays OK the next 3 weeks.
Thanks again for the fast answers guys
To check the ball joints, move the tire up and down while it is off the ground. Also some people use a bar to pry under the tire while it is slightly off the ground. Again, check for excessive play in the upper and lower ball joints.
JaySauce
12
Mar 15, 2009 12:48 AM
