TODA Racing Inc. Spec "D" Camshafts
Old Sep 25, 2002 | 09:37 AM
coquinn's Avatar
Default TODA Racing Inc. Spec "D" Camshafts
http://www.ericksracing.com/cams.htm
Old Sep 25, 2002 | 09:40 AM
Big Phat R's Avatar
Default Re: TODA Racing Inc. Spec "D" Camshafts (coquinn)
old newz
Old Sep 25, 2002 | 09:41 AM
coquinn's Avatar
Default My apologies
I did a search and could not find any information aside from the general talk of the camshafts. I was not aware everyone knew the specifications on these camshafts already.
Again, my apologies.
Old Sep 25, 2002 | 09:45 AM
Kengs's Avatar
Default Re: My apologies (coquinn)
So are these "Spec Ds" only available thru Erick's Racing (as the website seems to indicate)?
I wonder when Spec Es will be out...
Old Sep 25, 2002 | 09:46 AM
Big Phat R's Avatar
no need for the
Old Sep 25, 2002 | 09:47 AM
Willard's Avatar
too bad they are not suitable for your use...
Old Sep 25, 2002 | 09:52 AM
coquinn's Avatar
Default (none)
no need for the
I was bonking myself.
Old Sep 25, 2002 | 09:53 AM
coquinn's Avatar
Default Re: My apologies (Willard)
Why do you think I picked up the backup motor this week?
Old Sep 25, 2002 | 09:54 AM
Big Phat R's Avatar
Default Re: (none) (coquinn)
exactly - no need to bonk yourself.
Old Sep 25, 2002 | 09:55 AM
Drag R's Avatar
no need to apologize, no one new if they were available on the market.....so to hell with anyone who says its old new, cuz to everyone's knowledge they were only available to people they sponsor.....
later
Old Sep 25, 2002 | 10:02 AM
Hooch'n's Avatar
Default Re: My apologies (Top Fuel ITR)
They will own all
Old Sep 25, 2002 | 10:04 AM
Willard's Avatar
nice... "D's" in the daily drive motor.... and 'specal sauce' for the track motor... :DROOL:
Old Sep 25, 2002 | 10:25 AM
Suprdave's Avatar
I want some....:D
Suprdave
Old Sep 25, 2002 | 10:26 AM
GokuSSJ4's Avatar
since i havent spend to much time on H-T lately
hadnt seen this ....
Old Sep 25, 2002 | 10:42 AM
Reid's Avatar
Global Moderator
What are you talking about?
Old Sep 25, 2002 | 11:53 AM
slofu's Avatar
are these measurements taken at 1mm lift?
Valve Lift Duration
Intake Primary 11mm 250
Intake Secondary 12.9mm 305
Intake Hi 11mm 250
Exhaust Primary 11mm 250
Exhaust Secondary 11.9mm 315
Exhaust Hi 11mm 250
(ramp angles/rates would be nice.)
is it true that Skunk2 Stage 3s have the same primary lobe profile as standard B16a cams since they were originally designed to be vtec 'killers'? otherwise, for the $ they seem like a better buy: ~$1150 - ~$715 = ~$435 for springs/retainers.
Skunk2 stage 3 12.8 mm, duration 273 @ 1mm 11.5 mm, duration 273 @ 1mm
Toda's big primaries seem to make more (power) difference in the low/midrange with larger (~84mm) bore; otherwise, s2 stg 2s and jun 3s have good specs, seem easier to tune (at least for idle), and aren't as hard on the valvetrain (out of VTEC). they also don't seem to require high compression as much for low/midrange, due to milder primaries; after ~6k rpm, this does not seem as much an issue. of course, if i had ~84mm bore, i'd sell the s2/stg2s and go with Toda Bs, and if i were drag racing, i would not worry about idle or be out of VTEC.
also, i searched, but could not find the specs for any of the Skunk2 primary lobes. does anyone have them?
Old Sep 25, 2002 | 11:58 AM
sgT's Avatar
sgT
Default Re: TODA Racing Inc. Spec "D" Camshafts (slofu)
no
Old Sep 25, 2002 | 01:12 PM
Black R's Avatar
25 Year Member
Default Re: TODA Racing Inc. Spec "D" Camshafts (sgT)
.....whoa, those are erick's custom grinds!
Now how did he manage that one? I know he's got a shady reputation with some big industry people now...
Old Sep 25, 2002 | 02:05 PM
Hooch'n's Avatar
Default Re: TODA Racing Inc. Spec "D" Camshafts (Black R)
looks like their is going to be some hell raising....................
Old Sep 25, 2002 | 02:22 PM
xJ.SLOTHx's Avatar
so basically.....whos gonna test these cams out??? hahaha, for some reason im excited about these...i dunno why?...
Old Sep 25, 2002 | 04:39 PM
GokuSSJ4's Avatar
Default Re: TODA Racing Inc. Spec "D" Camshafts (ian)
i will will let you guys know whats up , since im having a 2.0l built by
Ericksracing.com the cams just recently became available to the public .
holset b18c
Nov 14, 2009 07:10 PM
CrX-WoRlD
23
Mar 23, 2007 03:16 PM
lsvtec101
Apr 24, 2003 09:32 AM
