97 civic ex steering wheel shake at 60 mph
Old Feb 10, 2011 | 01:08 AM
hatchet_honda's Avatar
Default 97 civic ex steering wheel shake at 60 mph
my friends gf has a 97 civic ex coupe. i just replaced both her cv axles because they were at the point of snapping. pretty bad. i bought 2 new ones from oreilys autoparts and installed them. well she now says that driving home from work on the highway her wheel shakes and the car pulls to the left at about 55-60 mph now. car drove fine with no speed issues before. think its a good guess that maybe the drivers side axle is bad although its new? i hear it happens alot with new axles.
Old Feb 10, 2011 | 01:20 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 97 civic ex steering wheel shake at 60 mph
Possibly, I have it happen with both Autozone and Advance axles. I would just make sure all your bolts are tight from the repair and if all is ok swap the axle.
Old Feb 10, 2011 | 09:30 AM
im doing her brakes this weekend. im gonna have to check and see if everything is tight. kinda lame if i gotta pull these axles out again..
Old Feb 10, 2011 | 09:32 AM
Former User's Avatar
You may need a wheel alignment after replacing the axles.
Old Feb 10, 2011 | 09:34 AM
i dont see how...why would axles affect alignment? tie rods were untouched and the car is sitting on stock suspension.
Old Feb 10, 2011 | 09:44 AM
Maybe the alignment had been adjusted for the bad axles and the new good axles require a different alignment. An alignment is recommended after replacing an axle (see step 12 in service manual below).
Old Feb 18, 2011 | 11:43 PM
installed the new brakes and noticed the drivers front tire has a big dent in the rim. she had to hit a pothole pretty damn hard to bend the steelie lip like that.
Old Feb 19, 2011 | 09:26 AM
D3vin's Avatar
You definitely need a alignment and maybe rebalance your wheels. That dent on the rim can really affect the balancing of the tires, 60mph+ shaking.
Old Feb 19, 2011 | 11:56 AM
Burton7706's Avatar
I with d3vin. alignment and balance is prob needed. i have the same thing goin on. just purchased 99 civic ex 4 door. good times ahead.
h22acd5
Mar 23, 2021 01:50 PM
92teginsc
Aug 12, 2008 02:09 PM
VIS250P
Feb 5, 2007 08:37 AM
ghettols
Aug 22, 2003 11:57 AM
wusta515
Oct 16, 2001 02:08 PM
