Need alot of part to finish sleeved B20 vtec turbo build!
These are a few of the parts I need to finish my b20 vtec turbo build.
-B18/20 main girdle
-B18/20 oil pan, tapped or not, no dents
-Gsr/Type R oil pump
-Gsr/Type R water pump
-Aftermarket Cam Gears for B-Series
-Obd1 vtec dizzy
-85mm ls forged pistons (must come with wrist pins)
-85mm ls/v head gasket
-Poly motor mounts for dc with B-Series
-Polished Throttle Body
-Arp Main Studs for B18/20
-Single disc clutch (not stock)
-Lightweight flywheel
-B18/20 main girdle
-Obd1 vtec dizzy
Got your throttle body and clutch here, let me know.
http://www.hondamarketplace.com/show....php?t=2895261
Interested in a Golden Eagle 95mm crank and 85mm JE pistons(with wrist pins, locks, rings)? Also have Clevitte main and rod bearings if you need some...just throwing it out there.
Charltons_Trix
Mar 25, 2008 06:17 PM
