how much is this civic worth?
its a 98 civic hx 2 door black has 120k on the body told 85k on motor when i bought it and had it swapped in
has a b18b1 swap with gsr tranny
lowered 2 inches on springs tein i believe
polished newer lx wheels - gonna have konig retracks on it in a few weeks
intake
ebay exhaust/noname header
innovative 95A solid motor mounts
body is about 7/10 few dings here and there
interior is about 7.5/10
headunit, system
8k hid
the bad
running a civic cx ecu (ls ecu wont work with hx harness) i will have a ex harness with the ls ecu in it shortly.
ebay exhaust, doesnt sound too bad wish i didnt cheap out though
burns a little bit of oil
tranny makes a little bit of noise when idles (input shaft)
overall is a solid car just want some thoughts of how much i could get for it so i can see if i wanna sell or keep and fix up more and boost
thanks - Alex
intake
headunit, system
8k hid
the bad
thanks - Alex
http://www.facebook.com/photo.php?fb...678728205thats
the only pic i have on my of it on my facebook
and the tranny makes noise since the ******* who swapped it put gear oil in my tranny and ever since then it makes a little bit of noise when idlein im just ocd and notice every little noise, u have to listen very closely to hear it so idk if it is the input shaft or anything major not sure im just guessing its that
Those cars are pretty hot over here in cali, to give u an example about a week ago our place had a 99 with 175k and it sold for $5,995, clean it up you should get 4k easy.
not argueing on ur input to a price i appreciate your opinion i was gonna ask 3k for it on craigslist but ill put like 4 and see what happens thanks
yeah if u can find a tuner guy that wants it. it shouldn't be that much of a problem getting rid of. id put 3500 and see what kinda hits u get. a lot of people they try to low ball if u set ur price too low make sure u put FIRM.
Like most have mentioned....$4000 OBO sounds reasonable. Just make sure to let potential buyers know about the oil consumption and other issues. Be as honest as you can when selling it.
Just run a '96 - '99 LS ECU, plugs right in. If you're planning on trying to run a '99 - '00 Civic harness and an '00 - '01 Integra ECU, forget it, not gonna happen. ECU has an immobilizer and using that harness combination will leave you with no tach or speedometer.
SGTechrepairs
16
Feb 19, 2013 08:34 AM
