Compression test results.. you are not the father
Old Feb 9, 2011 | 07:29 PM
SilkyJohnson's Avatar
Default Compression test results.. you are not the father
Whats up guys, just did my compression test and well.... things don't look good.. lmk what you guys think!
210
160
150
210
What should be my next steps????
Old Feb 9, 2011 | 07:31 PM
Former User's Avatar
Default Re: Compression test results.. you are not the father
Do cylinder leak down tests to pinpoint where compression is lost. My guess would be a bad head gasket with two adjacent bad cylinders.
Old Feb 9, 2011 | 07:41 PM
hmmm need to get my hands on leak down tester and air compressor
Old Feb 15, 2011 | 10:49 AM
UPDATE: did oil change -which was super gross oil.. change the spark plugs did another compression test
210
190
190
210
I think anything above 180 is good to go correct?
Pretty weird what a little freshin up can do!
Old Feb 15, 2011 | 10:59 AM
grumblemarc's Avatar
The Grumpiest
That looks much better but the same 2 cylinders are still suspect. If it were me I wouldn't stop there. Did you do a leakdown test?
Old Feb 15, 2011 | 11:02 AM
na no leak down test yet.. I'm thinking it might be the valves
Old Feb 15, 2011 | 11:05 AM
JdmCoupe91's Avatar
Did you do a wet compression test ?
Or dry ?
If not, try a wet test in #2 and 3 cylinders...
If compression rises, you need compression rings...
If not then continue with any other suggestions.
Hope everything works out.
Old Feb 15, 2011 | 11:46 AM
whats a wet compression test.. im guessing i did a dry one
Old Feb 15, 2011 | 03:45 PM
virgineg6's Avatar
poor some oil into each cylinder before the compression test.
Old Feb 15, 2011 | 04:04 PM
darksolderx's Avatar
here silky chemical leakdown tester
http://www.amazon.com/UVIEW-560000-C...7818167&sr=8-5
when you use it if the chemical turns a different color youll know if your headgasket is blown its somewhat pricey but they do work
92lxsleeper's Avatar
what engine is this? if its a b7 i'll defiently say headgasket being that the b7 is known for poor cooling efficiency between cylinders 2 and 3
Old Feb 15, 2011 | 05:26 PM
b16 from a 00 civic si
Old Feb 15, 2011 | 05:36 PM
JarvisW's Avatar
Sol to Sol
Is your exhaust manifold cracked in the center?
Thats how my Dads D16 lost 2 exhaust valves on the highway. (in #2 and 3) Tho I bet its the gasket too..
Also, I think I got my LDT from Harbor Freight, for a couple 20s.
Old Feb 15, 2011 | 05:54 PM
98civdx's Avatar
Master Detailer
Drip a little oil into those 2 and re-test. Do it right before you test it.
92vxjdm
Aug 15, 2008 05:05 AM
humboldt_skim
May 31, 2008 08:18 AM
Got_soy
28
Aug 8, 2005 12:49 PM
Azcheron
Jun 23, 2005 09:34 PM
lazyguy
May 5, 2002 01:36 PM
