2000 Honda civic ex radiator fan not working
Old Feb 9, 2011 | 05:21 PM
jrodart's Avatar
Icon2 2000 Honda civic ex radiator fan not working
What else can I do?
Hello everyone. I recently ran into problem with my radiator fan. I saw the temperature gauge going up above normal and I checked under the hood. The radiator fan was not working and it didn't work even after having the car on idle for 20 minutes. I replaced the fan relay. I replaced the sensor that turns the fan on as well as the coolant temperature sensor and it still doesn't work. I also checked the fan motor and itworks. Oh, and i have a new radiator.
Old Feb 9, 2011 | 06:55 PM
apexi_rsx's Avatar
Default Re: 2000 Honda civic ex radiator fan not working
you need to jump the plug in the harness that goes to the sensor on the thermo housing with a paper clip then mess with the wires to the fan.(jumping the plug makes the fan run) im sure u have a short somewhere in ur wiring or a fuse.
Old Feb 9, 2011 | 07:18 PM
beeseeries's Avatar
Voltage at fan? Voltage at ECT? Voltage at Relay?
chrisalvar
Jan 29, 2012 05:15 PM
hunter349
10
Jul 1, 2009 06:02 PM
jdmdc2boi12
Jan 26, 2009 07:05 PM
joel
Oct 17, 2001 09:54 PM
