Throttle Cable Diagram??
Old Feb 9, 2011 | 03:20 PM
Repko's Avatar
Default Throttle Cable Diagram??
Searched the Forums and couldn't come up with anything..
Would anyone have a pic or diagram of the throttle cable connections..
Took my throttle body and intake off for a througho cleaning, just wanna make
sure I attach it right.
Thanks in Advance!
Old Feb 9, 2011 | 03:33 PM
GhostAccord's Avatar
Default Re: Throttle Cable Diagram??
Make model year?
This actually should work for most years
Old Feb 9, 2011 | 05:22 PM
Repko's Avatar
Originally Posted by GhostAccord
Make model year?
Sorry 1996 Honda Accord EX 4cyc V-Tec
Like I have all the little plastic spacers just a little confused at to what order I slide them on then the spring over it.
Its consisting of the large spring that goes in between, then 3 plastic spacer and 2 metal. Hard to explain if I need to a shoot a pic of it.
Old Feb 9, 2011 | 05:38 PM
That image is for the 5th gen Accord throttle cable setup. so it should help you out.
Old Feb 9, 2011 | 06:17 PM
Repko's Avatar
Heres some pics of what I mean
Lets say for the parts I have 1 through 7 From left to right.
Can someone tell me k part 5 the bigger metal spacers goes first then part 6 then the spring ect?
And I believe that I but the bottom left black part on correct?
Old Feb 9, 2011 | 07:30 PM
They should go onto your throttle body as follows, from left to right on your image,
Throttle body - 5 - 6 - 1 - 3 - 4 - 2 (there are 2 parts here) - 7, Make sure that you give the spring a full 360 turn before you hook it up or you won't have the proper tension.
Here is my F22 TB taken apart in order;
Seems like you are missing the lock washer that goes on before the nut.
Also the metal nub should be on the left side of that black plastic pull tab.
Old Feb 9, 2011 | 09:21 PM
Repko's Avatar
Thank you so much! And for the info on the twisting the spring, and I will be adding a lock washer know that you mention it!
As for the metal nub, all try spraying it and sliding over.
Thanks GhostAccord! Your gonna make my GF a very happy lady!
Old Feb 10, 2011 | 06:48 AM
No Problem
Hopefully, in turn, she will make you a very happy man
Old Feb 10, 2011 | 09:44 AM
Repko's Avatar
Alright! Shes Together again! And I couldn't be happier with the results!
The idle jumping and high idle are completely gone!
And the metal nub explains why the cruise control wasn't working moved it over and its snug again.
Next step is trans fluid change. Thanks made her and me a very happy man!
Old Feb 10, 2011 | 09:56 AM
Repko's Avatar
So I know this is off Topic from my original thread, but you seem like the person to ask..
For changing out the Transmission fluid in my 1996 ex auto trans, the drain plug should be visible on the bottom, and you fill it through the dip stick port on the top right?
Old Feb 10, 2011 | 11:51 AM
View from passenger side wheel well;
Yes you fill it through the dip stick tube. Also make sure that you get the engine/trans up to operating temp (rad fan comes on) before you do the fluid change. Be careful the fluid will be warm, having it warmed up makes it easier to drain.
Old Feb 10, 2011 | 12:46 PM
Repko's Avatar
Alright thanks that was a peace of cake compared to other vehicles..
Now I just have to solve this overheating issue and I'm praying I don't need a head gasket.
Old Apr 29, 2014 | 10:55 AM
dumppantz's Avatar
Would anyone happen to have a diagram of any sort on this exact thing for a 2001 Honda Civic? Lol
Old Apr 29, 2014 | 01:31 PM
dumppantz's Avatar
Never mind figured it out!
Old Nov 9, 2023 | 02:09 PM
C.McDoogz's Avatar
Hi guys. New here. I messed up and took the 11mm bolt off the throttle body linkage of my 2003 Ody and can't seem to find any information on reassembling it the correct way. I saw this thread and was excited to finally get some good info, but I can't see any of the pictures that anybody shared. I don't know why 😭 plz help
EgK2o09
Dec 30, 2010 11:34 PM
rasta420
Mar 19, 2003 06:36 PM
The_In_Kid
Dec 14, 2002 04:49 PM
dust1
May 9, 2002 07:15 PM
