my D15B8 is burning oil and not smoking, not sure why please help!
Old Feb 9, 2011 | 12:11 AM
r.etheridge's Avatar
Default my D15B8 is burning oil and not smoking, not sure why please help!
I have a 94 coupe DD with a D15B8 engine in it. It only has 150k miles on it and it burns oil like crazy. It doesnt smoke at all, it runs strong, it drops about 2 oz of oil every 3,000 miles (between oil changes) but I have to add about a quart of oil every 1,000 miles or so. Where is this oil going?
Old Feb 9, 2011 | 05:08 AM
g35silversurfer's Avatar
Default Re: my D15B8 is burning oil and not smoking, not sure why please help!
dude. how do you know your not burning it???
i have a jdm d15 vtec and if it's in the driveway and someone pushes the gas pedal pretty far down it doesn't smoke at all.
but you cant see smoke if your at 6000rpm shifting down the highway. you wont see it. Unless it's a REALLY bad burning problem.
it's your rings. it's got 150k miles. they're just getting worn.
I have to add a little oil to my engine every other week. If I drive it nicely and concentrate on shifting better instead of racing ppl I don't burn hardly any oil. but if I take a long road trip and rev far to pass ppl etc. I will lose a little oil after a couple hundred miles.
Old Feb 9, 2011 | 06:32 AM
fatpride111's Avatar
youre either leaking it or burning it. No other way to lose oil in an engine.
Try a can of Engine restore. they sell them at Oreillys/autozone for like $10, and they can help with oil consumption. Its about all you can do unless you want to tear apart the engine, and replace the seals.
If its your valve seals, it wont be that hard of a job. Just time consuming.
Old Feb 9, 2011 | 08:59 AM
I thought it might be my rings. I know im burning it, I really ment to say why am I burning so much but just didnt know why. So it could be my valve seals as well?
Old Feb 9, 2011 | 09:03 AM
whats throwing me off on it being rings is I feel like im not losing any compression. I still have all the power like I did before it started to burn so much
Old Feb 9, 2011 | 05:51 PM
EFPhilly's Avatar
Hammer on the gas while going down the road to the floor...If it smokes there it is the rings. Drive faster than normal then compression brake and if it smokes there valve guides. Its all based on the vacuum of the motor with where it leaks. That is the ghetto way to check it but works!
Old Feb 9, 2011 | 11:16 PM
eghatch9295's Avatar
Stancetard Hate Monger
if it sits awhile, awhile being at least a day, does it smoke when you first start it?
Old Feb 10, 2011 | 12:19 AM
yeah but its cold here right now so all my vehicles smoke on start up. But the honda does a little more than the others. I just thought it was because its a 94 and everything else we have is pretty new.
Old Feb 10, 2011 | 12:23 AM
ok so my wife goti n the car and i told her to run it up to 4k rpm's and I got a light white smoke. This took place after the car was already at normal running temp. So im figuring that I should change the piston rings and while the motor is out of the car, go a head and replace the valve stem seals and guides and maybe the valve stems as well
Old Feb 10, 2011 | 08:09 PM
EFPhilly's Avatar
You only did it one of the ways
Old Feb 10, 2011 | 10:03 PM
oil smoke is blue. blown headgasket is white.
Old Feb 11, 2011 | 12:11 AM
EFPhilly's Avatar
Hmm what about synthetic oil...believe it burns white Compression test should should and if not leak down.
Old Feb 11, 2011 | 12:17 AM
Im not running synthetic and the smoke was blue. Ill try to run a compression test this weekend
Old Feb 11, 2011 | 12:22 AM
EFPhilly's Avatar
Do that little test then to see valves or pistons. Sounds like you did one part...do the other. You can always take the heads apart and use a valve lap tool and medium then fine polishing compound to reseat the valves while its apart. costs like ten bucks tops. Most likely the rings and the compression test will tell if the rings are bad, remember to do a wet test after the dry test.
Let me remind you:
ok so my wife goti n the car and i told her to run it up to 4k rpm's and I got a light white smoke This took place after the car was already at normal running temp.
So which is it??? Sounds like you are confusing yourself.
Old Feb 11, 2011 | 07:21 AM
92lxsleeper's Avatar
2 oz of oil isn't that much. and fyi all engines burn a little oil. its normal.
Old Feb 11, 2011 | 09:33 AM
Let me remind you:
it was more like a blueish smoke. Im going to do a compression test then a leak down test this weekend. If the compression test is good, i would suspect its the valve seals. so the compression test should be what? ive heard 150 but is that the minimum it should be?
Old Feb 11, 2011 | 09:35 AM
I agree with 2oz leaking isnt that much but its not normal that an engine burns 1q of oil every thousand miles
Old Feb 11, 2011 | 09:37 AM
EFPhilly's Avatar
Wrong. Vtec does not use oil, oil scraper ring controls oil loss, crankcase oil is re-vented into the intake via PCV. No oil should be loss on any engine. Go on youtube...find a nice fully built turbo by a good shop and watch it on the dyno. No smoke will be seen even at high rpms. Good built motors do not burn oil.
The only motors that use oil are rotary engines (not sure about the new renesis). They use oil because the oil jets on the eccentrical shaft spray a small stream of oil to lubricate the rotors.
Old Feb 11, 2011 | 01:10 PM
So I have a haynes manual but it doesnt have steps to perform a compression test or leak down. Can someone PM me and walk me through it step by step or give me a link? I searched but didnt get anything
Old Feb 11, 2011 | 01:12 PM
and whats the difference between a wet and dry test?
Old Feb 11, 2011 | 01:23 PM
and whats the difference between a wet and dry test? also, do you do it on a cold or warm engine?
Old Feb 11, 2011 | 07:33 PM
AutoXer's Avatar
He didn't say VTEC, he said engines, and every Otto cycle combustion engine does burn oil. Most of the time, it's not enough to notice. I've found it's a bit higher on Hondas due to the compression ratio; which is especially apparent in a VTEC motor.
Just because you don't see smoke doesn't mean no oil is being consumed. Has nothing to do with being built or whatever, because even the best will consume some oil. Rotaries do consume more than an Otto cycle due to the design. The renesis is knocked for that all the time, and there have been engine failures from oil loss. But even a new RX isn't blowing smoke out the back while consuming oil. If you see smoke, something is really wrong.
WIhondas
Honda CR-V & Element
Nov 2, 2011 07:22 AM
fernando.
33
May 1, 2009 09:28 AM
creator1322
Sep 20, 2007 03:09 PM
oMek
Mar 2, 2004 07:25 PM
