DA motor shakes when shifting gears
Old Feb 8, 2011 | 10:59 PM
ej1916's Avatar
Default DA motor shakes when shifting gears
My 1990 Integra seems to shake everytime I shift gears. The motor shakes I believe. If I shift and let go of the clutch fast then the motor seems to shake. If I shift gears and slowly ease off the clutch then it doesn't shake at all. What could this possibly be? Also the clutch seems very light. I heard theres a way to adjust the stiffness of the clutch. How do I adjust this?
Old Feb 8, 2011 | 11:12 PM
Rediness_code's Avatar
Default Re: DA motor shakes when shifting gears
Have you checked the condition of your motor mounts?
Old Feb 8, 2011 | 11:16 PM
el crapitan's Avatar
^^+1. check motor and transmission mounts
Old Feb 9, 2011 | 05:08 PM
ej1916's Avatar
Motor mounts seems fine. Anything else? I'm worried that it might be a transmission problem.
Old Feb 9, 2011 | 07:11 PM
1998GsRIntegra's Avatar
Still a cable transmission?
If so, there's a **** on the clutch cable that can be used to adjust the clutch. It sits in a bracket mounted to the transmission. Looks similar to vin diesels nos ****. Lol. I know we've all seen that movie.
Old Feb 9, 2011 | 08:12 PM
how did you check the mounts? because a simple visual inspection is not enough to know
Old Feb 9, 2011 | 10:40 PM
Have someone try to take off in first while pressing the brake also, have the e-brake all the way up as well, a block or something to chock the rear wheels is a good idea too. While they try to take off in gear the motor should rock a little bit don't stand in front of the car while checking. that should point you in the right direction.
Are all the motor mount bolts nice and tight? anything stripped?
Old Feb 10, 2011 | 05:18 AM
you can also put it on the hoist and pry at the mounts with a large pry bar. see if there's any play. pry in all directions
Old Feb 10, 2011 | 02:37 PM
jvz555's Avatar
Could also be an axle problem.
TmantonyDC2
Jan 21, 2012 09:18 AM
enycesam
17
Jul 27, 2011 12:34 AM
accord_raffi
Jun 8, 2009 12:04 PM
bl1tzk1213g
May 11, 2007 07:09 PM
Jonzo
Mar 23, 2006 09:17 AM
