93 Integra Automatic Tranny Problems ...
So here is the story. I have a friend who bought a 93 Integ LS Auto with a bad head gasket for dirt cheep. He did not feel comfortable doing the head gasket by himself but he bought it anyways. His father then insisted on doing it for since he has done them before. Well his father got as far as putting the head back together and torquing it to spec (so he says). Well a friend of his said he will put the rest of it together. The friend went over and tried to help ... tried. I was then called and asked if i could put it back together since i am very skilled at doing this so i did. big mistake
. I basically had to take it back down to where his father got to. Here is the thing. After getting it running we set it down and seems the transmission (Automatic) is stuck in reverse. The car will crank over and start when the Driver Gear selector is in Park or Neutral but it is in reverse. I did check the linkage to the transmission and it is installed into the trans and clamped down. I put my hand on it and had him shift it from driver shift selector and i do feel it moving inside the cable. Do not really know what to do from here.
Oh btw when father did the swap he split the engine and transmission and then did put them back together. It does not sound to me like it is a problem with the torque converter but i almost always deal with manual trans and if i do deal with an auto i am the one working on it.
Please post and see what i can come up with.
thank you honda-tech world
. I basically had to take it back down to where his father got to. Here is the thing. After getting it running we set it down and seems the transmission (Automatic) is stuck in reverse. The car will crank over and start when the Driver Gear selector is in Park or Neutral but it is in reverse. I did check the linkage to the transmission and it is installed into the trans and clamped down. I put my hand on it and had him shift it from driver shift selector and i do feel it moving inside the cable. Do not really know what to do from here. Oh btw when father did the swap he split the engine and transmission and then did put them back together. It does not sound to me like it is a problem with the torque converter but i almost always deal with manual trans and if i do deal with an auto i am the one working on it.
check the codes at the trans control module. it should be behind the main relay
here's a wonderful little pdf with great diagnostic aids on troubleshooting a da auto trans
http://freeonlinerepairmanual.com/Ma...n%20Manual.pdf
bad part is they bought the car with a bad head gasket so they have no idea. i will play with it a little moe and if i do not find it ... t speed conversion time. thx guys
well, i'd try seeing if there is a code present before pulling it out. the module is up under the dash to the left of the steering wheel. there will be an led on it which will flash accordingly if a code is present
