eg/dc struts on da problem
i put some rear eg/dc tokicos on my da with the same tein lowering springs i already had and it lifted up the back up like 3 inches. i also took off my lca's so i could grease up the bushings. so what did i do wrong when i put everything back together? my lca's arent swapped around.
yea the sway bar is bolted up. the top hats arent tightened all the way and neither are the shocks but this shouldnt cause a 3 inch lift. shorter struts should lower my car right? i pushed down on the back of the car like 10 times and it still didnt go down
i actually put some rsr lowerin springs on my da but they were for a dc. and i took it out and tried mounting it to the da sturt and didnt fit...so u need to make sure ur coil and strut are the same ...u need a dc coil.....i had to do the entire conversion on mines both front and rear cuz the da coils slightly smaller and doesnt really mount the cup right....
i loosened my lca's and it still didnt go down so i put my da shocks back on and its still high in the back i have no idea what i did wrong? my springs fit perfect in both cups so i dont know what the problem is.
hmmm maybe u did over tighten the lca bolts...losen them and see if itll go down...if not u might need to redo everything and see if maybe it makes a diffrence
724chris
Jan 4, 2010 04:00 PM
