eg/dc struts on da problem
Old Feb 8, 2011 | 07:43 PM
92db2gs-r's Avatar
Default eg/dc struts on da problem
i put some rear eg/dc tokicos on my da with the same tein lowering springs i already had and it lifted up the back up like 3 inches. i also took off my lca's so i could grease up the bushings. so what did i do wrong when i put everything back together? my lca's arent swapped around.
Old Feb 8, 2011 | 07:49 PM
ElementzofR's Avatar
Default Re: eg/dc struts on da problem
never heard of this happening. are the springs for a DA or for an EG/DC? did they come with the shocks?
Old Feb 8, 2011 | 07:51 PM
92db2gs-r's Avatar
their tein s tech springs for a da
Old Feb 8, 2011 | 07:54 PM
thats really weird because DC rear shocks are generally like an inch shorter than DA shocks. i have the same setup on my DA with Tokico Blues
Old Feb 8, 2011 | 08:27 PM
92db2gs-r's Avatar
any ideas what i did wrong? i compared these struts next to the ones that were on it and the eg/dc struts are about 2 inches shorter
Old Feb 8, 2011 | 08:39 PM
sway bar bolted up? top hats bolted all the way down? maybe the springs just need to re-settle themselves
Old Feb 8, 2011 | 08:44 PM
92db2gs-r's Avatar
yea the sway bar is bolted up. the top hats arent tightened all the way and neither are the shocks but this shouldnt cause a 3 inch lift. shorter struts should lower my car right? i pushed down on the back of the car like 10 times and it still didnt go down
Old Feb 8, 2011 | 08:49 PM
tighten up the top hats. make sure the springs are sitting correctly in their cups, and check to see if you over tightened the lca bolts.
Old Feb 8, 2011 | 09:04 PM
92db2gs-r's Avatar
i might have over tighted my lca bolts
Old Feb 8, 2011 | 09:15 PM
maybe thats why
Old Feb 8, 2011 | 10:44 PM
92db2gs-r's Avatar
would that cause it to sit 3 inches higher and still go down when i push down on the trunk?
Old Feb 9, 2011 | 07:37 AM
loosen the lca bolts and see if the car goes back down
Old Feb 9, 2011 | 03:35 PM
el vtec monster's Avatar
i actually put some rsr lowerin springs on my da but they were for a dc. and i took it out and tried mounting it to the da sturt and didnt fit...so u need to make sure ur coil and strut are the same ...u need a dc coil.....i had to do the entire conversion on mines both front and rear cuz the da coils slightly smaller and doesnt really mount the cup right....
Old Feb 9, 2011 | 08:25 PM
92db2gs-r's Avatar
i loosened my lca's and it still didnt go down so i put my da shocks back on and its still high in the back i have no idea what i did wrong? my springs fit perfect in both cups so i dont know what the problem is.
Old Feb 9, 2011 | 08:37 PM
hmmm maybe u did over tighten the lca bolts...losen them and see if itll go down...if not u might need to redo everything and see if maybe it makes a diffrence
Old Feb 9, 2011 | 08:39 PM
did u also put new struts on the front?
Old Feb 9, 2011 | 09:13 PM
92db2gs-r's Avatar
no just the rear
Old Feb 9, 2011 | 09:50 PM
wow this is really starting to make me think WTF? lol
Old Feb 9, 2011 | 10:09 PM
92db2gs-r's Avatar
same here its really stressin me out lol
Old Feb 9, 2011 | 10:14 PM
do u have pics of the suspension and the 3 inch lift?
Old Feb 10, 2011 | 06:45 PM
92db2gs-r's Avatar
is it possible that i put my lca's on upside down?
Old Feb 10, 2011 | 06:59 PM
maybe??? sounds like a long shot but why dnt u try taking them off and putting them the other way see if it works
Old Feb 10, 2011 | 07:02 PM
lmao!!!! holy crap i never thought of that one. take some pics.
Old Feb 10, 2011 | 07:38 PM
92db2gs-r's Avatar
i will tomarrow
Old Feb 11, 2011 | 04:44 AM
Bowl_of_Rice's Avatar
hahaha you might have put it in upside down, the curve part of the lca is suposed to be towards the ground
92db2gs-r
Suspension & Brakes
Feb 8, 2011 10:42 PM
724chris
Jan 4, 2010 04:00 PM
teamols
May 11, 2009 06:50 AM
Soichiro's way@MF
Suspension & Brakes
Mar 20, 2007 12:36 AM
Paul1985
Feb 16, 2007 05:43 PM
