Exhaust leak--issue
Old Feb 8, 2011 | 02:15 PM
3Rd_gEn_LuDE's Avatar
Default Exhaust leak--issue
Ok well when i replaced my rack and pinoin i had to take out the exhaust pipe that
connects to the headers. its 4-2-1 and well the leak is coming from in between 4-2.
When i was putting the pipe back on i could not find the gasket that went in between, except for majestic honda but...80$ for a gasket...my morals wont let me..
Anyway here's a pic of what i did...
It was not as quiet as before, and now its LOUD AS ****. So i'm thinking i messed up, or are there better ways to make gaskets? Are there supposed to be O rings instead? I'm not sure
Old Feb 8, 2011 | 02:31 PM
Jockone's Avatar
Default Re: Exhaust leak--issue
You can't make an exhaust gasket out of cork gasket material.
From the looks of your header it takes 2 ring type gaskets best idea is to take lower pipe to parts store and match the gaskets or if not take pipe in and get a exhaust gasket similar to the one you tried to make.
Old Feb 8, 2011 | 03:15 PM
lol yea I tried that at autozone when i went hunting for it. The guy couldn't find any that fit, they then handed me the cork material, figured it was better than nothing. Would like a more permanent fix. I'll try at Napa or advance see what happens.
If i try to make one again what kind of material would you suggest? If anything I could just go to Lowes pick up some material and measure out some rings and fit them in.
Fyi: I have DC sport headers, and pretty sure the 2 pipe is oem. The rest of the exhaust is a Frankenstein build sounds great when its not leaking.
Old Feb 8, 2011 | 05:38 PM
netfreak's Avatar
I think I used some RTV Orange sealer when I put my header on. Mine leaks from somewhere else though haha
Old Feb 8, 2011 | 05:51 PM
vg_Ace's Avatar
the best gasket I have found that work quite well are Remflex. I have that same type of header and they do sell a gasket that size. They don't need to be torqued down all that much to make a good seal. They are quite thick too.
just google it.
Old Feb 10, 2011 | 05:02 PM
just google it.
I found it yes its $27.99. Shipping was gonna take a while so i ended up making my own lol. It took a while to find descent material, I ended up going to ace hardware and they pointed me to Napa. I bought a sheet of gasket material, two layers of the gasket material and I believe aluminium in between. $10 for a sheet and heres what i came up with:
Yeap its working pretty good, reaaally quiet just the way i like it
nows a test of how long it will last
mjf6866
Mar 15, 2015 02:32 PM
06dx-gblack
Honda Civic (2006 - 2015)
Apr 23, 2008 12:30 PM
mikeunreal
Nov 21, 2005 06:38 AM
bOOsTiNSoHcVtEc
Jul 14, 2005 03:42 PM
