Engine shuts off immediatly after start up
Old Feb 8, 2011 | 12:41 PM
91akira's Avatar
Default Engine shuts off immediatly after start up
91 DA
To make it start, I have to step on the gas and rev it high to start it up. Runs fine after that. Even starts up fine without reving it after a second or third trip. Something on its way out? What do you all think the problem is?
Things replaced OEM.
MFR 2011
Fuel filter 2011
Cap and rotor 2009
ignitor 2003
Old Feb 8, 2011 | 02:55 PM
dc4teg95's Avatar
Default Re: Engine shuts off immediatly after start up
I had this problem and my issue ended up being the power wire connector for the alternator being broke
Old Feb 8, 2011 | 08:28 PM
91akira's Avatar
anyone else?
Old Feb 8, 2011 | 10:44 PM
el crapitan's Avatar
does it shut off right when the key drops back to the II position immediately after start up? if so, when that happens, do the gauge cluster lights stay illuminated? or no illumination whatsoever?
Old Feb 8, 2011 | 11:14 PM
if you haven't assumed already, i'm leaning towards ignition switch
Old Feb 8, 2011 | 11:50 PM
VVENOM800TT's Avatar
Most likely the ignition switch, its a $50 dollar part from honda
Old Feb 9, 2011 | 08:35 AM
91akira's Avatar
hmmm... right when the key drops back to II the car shuts off. As for the cluster lights staying illuminated? I forgot to observe this one. I'll have to wait until it happens again. So if they do stay on, the ignition switch is ruled out right?
Old Feb 9, 2011 | 08:17 PM
yes
Old Feb 11, 2011 | 05:29 PM
91akira's Avatar
Yup I just started it and no illumination on the cluster.
I've seen a DIY on cleaning the switch. You all think I should go this route or should I fork up 50 bucks and buy another one?
No harm for me either or. I just wanted if cleaning the contacts on the switch is going to extend the life of it.
Old Feb 11, 2011 | 08:29 PM
OEM92GS-R's Avatar
new one from honda.. honda parts can last ova 100,000 miles
Old Feb 12, 2011 | 04:42 PM
91akira's Avatar
Wow the San Diego dealership switch is about 100 bucks!! Out of state such as arizona or florida cost half of that.
Old Feb 12, 2011 | 05:21 PM
I paid like 50 for mine
Old Feb 14, 2011 | 08:19 AM
91akira's Avatar
Just an update on the switch replacement
I went ahead and cleaned it up instead of buying a new one. There were a few things to remove just to get to get access to the switch itself. (knee bolster, and steering wheel etc.) You'll need an L shaped phillips screw driver just to get the two screws holding the switch down. I didn't bother taking the whole switch out of the car. I didn't want to bother unrouting and snipping tie wraps. I let it dangle and cleaned the other half on my bench with a dremel rotory tool. Thank God for that. Much faster and easier. So far starting up is good. Thanks guys for your help.
BTW. My switch looked dirty just like the DIY pictures.
jeffstaples1982
Honda CR-V & Element
Oct 2, 2017 11:51 AM
95greenlude
Dec 24, 2007 07:01 AM
RJH6
Honda Motorcycles
14
Mar 19, 2005 01:49 PM
W0oT
25
Sep 23, 2004 11:21 AM
neutron91
11
Dec 5, 2003 02:04 PM
