Honda CR-V & Element 2WD & 4WD Element & CR-V
IAC valve 98 CRV
Old Feb 8, 2011 | 10:03 AM
decode33's Avatar
Default IAC valve 98 CRV
Hello I have a 98 crv in good condition with 245k kms on it. I am sometimes having high idle problems same as this below.
http://www.crvownersclub.com/forums/...read.php?t=462
My question is can I use carb cleaner instead of throttle body cleaner to clean the IAC valve (Idle Air Control valve). I am in saudi arabia and they do not sell throttle body cleaner here. Only thing available is carb/choke cleaner. I do not want to damage anything like sensors or engine. Any idea.
Old Feb 8, 2011 | 11:58 AM
MonkeyMagic's Avatar
Default Re: IAC valve 98 CRV
yeah remove the iacv and spray it with the carb cleaner.
Old Feb 19, 2011 | 10:35 AM
laloquera916's Avatar
Shoot! Ive use cleaning brake fluid! Just make sure its nicley air dried, and u should be good. Also, for high and eradic rpm surges, I reset the base ignition and ignition timing. Just fallow the proceedure in the haynes manuel or look up DYI write for this procedure.
Peace in da Middle East my brother!
92cb7sk8er
Jun 21, 2011 12:34 PM
nik_gujarathi
Feb 10, 2011 04:51 PM
MrExclusive
Feb 17, 2010 08:41 AM
thunderboy
Sep 2, 2008 03:41 PM
bluedelsol
May 25, 2003 08:11 PM
