Hub/Bearing issue
I have 1997 Civic Ex knuckles on the front of my 1994 Cx. The driver side hub bearing has some issues and the hub has received some damage...unfortunately I cannot seem to locate a hub for a 1997 Civic Ex. It's not listed on Majestic, it's #3 under the "front brakes" tab, it's actually skipped on the list. The Napa store I brought the knuckle to does not carry a hub, neither does Advance Auto or Auto Zone. A friend has given me some Cx knuckles off of his eg hatch, I tried checking to see if the hubs were the same but since the hub isn't listed online, I couldn't get a PN to check. I also tried checking if the knuckles were the same but obviously the PN's are going to be different because ek knuckles have mounting tabs for brake lines on the knuckles and eg's do not. If, in fact, the knuckles are similar, I'd appreciate some confirmation so I could just transfer the calipers and rotors over to the cx knuckles. If thats not the case I'd appreciate if somebody could check if the hubs are the same so I could use the hub out of the cx knuckle.
Hub bearing PN's-
1994 Cx: 44300-S04-008
1997 Dx: 44300-S04-008
1995 Ex: 44300-S5A-008
1997 Ex: 44300-S5A-008
Hub PN's-
1994 Cx: 44600-S04-980
1997 Dx: 44600-S04-980
1995 Ex: 44600-S04-A00
1997 Ex: ????
Knuckle PN's-
1994 Cx: 51215-SR3-000
1997 Dx: 51215-S04-980
1995 Ex: 51215-SR3-N10
1997 Ex: 51215-S04-N10
Hub bearing PN's-
Hub PN's-
1997 Ex: ????
Knuckle PN's-
hondapartsunlimited.com shows this for the '97 EX hub
44600-S01-A00 HUB ASSY., FR.
44600-S04-A00 HUB ASSY., FR.
i also found hubs and hub assemblies (hub shaft, bearing, ABS ring, studs...) on O'Reilly's website. they also cross-reference fitments and it shows both the CX and EX in the same category for the years you've listed.
on a side note: O'Reilly seems to have the most useful, informative, straightforward site of all the parts stores.
Thanks, I actually just visited Honda to pickup a ground plug for the driver side headlight harness and asked about the hub. The guy said they had to order it from a supplier in California and it was in the ballpark of $240 LOL. I gave him my list of PN's w/ prices, he said get the 95 Ex hub, it's the same PN and obviously since Majestic has it for $122 that would be a better route.
JohnnyEF
Apr 9, 2014 10:16 AM
beaneg6
Oct 20, 2006 12:30 PM
05, 44300s04008, 44300s5a008, 44600s01a00, 44600s04980, 44600s04a00, bearing, civic, cross, honda, hub, oreilly, part, problem, reference
