Camber kits. What're you using?
Old Feb 8, 2011 | 12:18 AM
Fo-Do Fanatic's Avatar
Default Camber kits. What're you using?
I realize this may have been covered with threads like "which camber kit is best y0!" or "I need help deciding a camber kit"
I'm curious how you guys/gals are liking/disliking your camber kit, I.E Skunk2, Ingalls, Progress, Ebay etc...
I'm in the market for one. I have 5.5* of camber up front DA knuckles and tucking tire up front is not so good for camber lol.
Input?
Old Feb 8, 2011 | 12:26 AM
hatchet_honda's Avatar
Default Re: Camber kits. What're you using?
i have skunk2 upper arms w/adjusting balljoints. no problems
Old Feb 8, 2011 | 12:58 AM
Surfjunkie44's Avatar
I have an Ingalls kit in my 1991 Si. Here are my complaints:
1) The nickel-plating (chrome) is cheap, and as with all chrome, it will eventually crack or flake leaving exposed metal that will eventually corrode and doesn't look pretty if you're really **** about the showmanship of your wheel well (just being honest).
2) The body of each camber piece will eventually begin to ream out from the bolt. I have 218k on my car, but have no idea how long this kit has been on the vehicle. I can only account for what I am encountering at this juncture.
3) Adjustment on the Ingalls kit is not the most simplistic design. After viewing the Skunk 2 kit (front), I was rather impressed with their piece, especially for ease of adjustment. The price is also only $10 more than the OEM replacement upper control arm with ball joint. I have no experience directly with the Skunk 2 product, but will suffice that it will be my next purchase when that time arrives to replace the current Ingalls kit.
Hope this information helps.
Old Feb 8, 2011 | 07:28 AM
.Manny.'s Avatar
Touching My Member
Call Jeff "Kiwi" at Specialprojectsms.com , they should have the new Hardrace Camber kits in already, if not, soon.
The hardrace kits are a lot beefier than any other kit I've seen. The bolts on there are fatties.
Old Feb 8, 2011 | 07:49 AM
crx_si-r's Avatar
Input?
im running skunk2 front and rear camber kits. i bought the fronts new for $210, was contemplating buying oem replacements and installing the adjustable ball joints on them and have everything new. but price came out to more than the skunk2 kits. so i went with those instead. then found the rear camber kit on craigs for $50. so far (couple months) no complaints from me. i have heard that the cheaper knock offs on ebay have clearance issues, but the skunk2 it clears no prob. here are some pics
Old Feb 8, 2011 | 10:08 AM
3Rd_gEn_LuDE's Avatar
They're finally making for ef/crx SWEEET, start saving up lol. I have a cheapass godspeed kit. I would only recommend if you have some sort of toe/camber issue that you want straighten out. 30$ plus 50$ for an alignment and it works, been on for about 3k miles. Good for a cheap fix.
Old Feb 8, 2011 | 10:31 AM
kymyer's Avatar
i am running ebay front and back with no clearance problems at all on my EF hatch i have 15x8 +12 offset and no rubbing.. so far so good. ill post more if i run into any problems.
Old Feb 8, 2011 | 10:41 AM
dacrxguy's Avatar
I ran a couple of sets of ebay camber kits in the past. they are good for about a year the until the bushing give out. I put my stock shocks back on riding with stock up and lower control arms.
Old Feb 8, 2011 | 01:59 PM
Kind of off topic, but can any of you guys snap some pictures of your front UCA's? I think I have mine on backwards The one picture up there is fine, I just wanna see more just in case.
Old Feb 8, 2011 | 03:08 PM
Jack your vehicle up to allow the suspension to reach its full travel. Remove your wheels. With a flashlight, look at the top portion of the UCA. It should be stamped with an "L" for left or an "R" for right. There is also a stamp on the brace, but that will be much more difficult to see without removing the coil spring assembly.
Old Feb 8, 2011 | 03:32 PM
maritime_ef's Avatar
Running skunk2 fronts and my alignment guy just shimmed the rear for me
Old Feb 8, 2011 | 08:50 PM
hatcht9x's Avatar
I have Skunk2 in the front. No name in the back. I have what I consider to be a modest drop on my car.. (can still stick a finger or two between tire/fender) and my Skunk2 kit is already slammed as far out as it can go.. I thought I would have way more room to play with if I ever wanted to go lower.. Again I consider my drop MODEST compared to what I have seen and even to where I want to be.. so what do I do when I want to go lower but retain my correct camber? No quality complaints.. but I feel restricted.
Old Feb 9, 2011 | 07:33 AM
crx_si-r's Avatar
im sitting at i think 22.5" or 21.5" from the ground (to center of headlight). 1/2 above the legal limit and i still have plenty of play with my front S2 UCA.
Old Feb 9, 2011 | 01:58 PM
Nooch's Avatar
This should get stickyed in FAQ's to help out people.
Old Feb 9, 2011 | 03:48 PM
If it gets more replies and tech in it, I don't see why it shouldn't be stickied.
Old Feb 9, 2011 | 06:37 PM
asianflava's Avatar
No one has mentioned Specialty Products Company, I had their stuff years ago. I drove by for months before I realized that I worked next to them.
http://www.specprod.com
Old Feb 9, 2011 | 09:04 PM
Creator's Avatar
I'm running revo technica on mine. They where ok on the street(on the car for about a year). I did have to do a very minimal amount of trimming on the fender well joint, and my car is by no means slammed.
Now that I've been road racing it...the ball joints don't last longer than one race. I've heard good things about the skunk2s.
Old Feb 10, 2011 | 08:46 AM
hatcht9x's Avatar
[QUOTE=hatcht9x;44618537]I have Skunk2 in the front. No name in the back. I have what I consider to be a modest drop on my car.. (can still stick a finger or two between tire/fender) and my Skunk2 kit is already slammed as far out as it can go..QUOTE]
is nobody else experiencing this? my camber is correct but I have no more adjustment abailable
Old Feb 10, 2011 | 11:30 AM
Nickster's Avatar
Skunk2 f/r here, no problems really... I just wish the fronts were easier to adjust on an alignment machine. On the rear you just adjust the bolt, on the front the ball joint slides into whatever random position it's in when you tighten it down. I think a front UCA, like this one Endyn is using on his GrandSport, would be great:
(sorry for the size, it's borrowed!)
IIRC, those rear Skunks you have are on upside-down.
Old Feb 10, 2011 | 12:54 PM
Loring_L_Jr.'s Avatar
My CRX came with ingals (not sure on how to spell that) and i havent had any problems. i like it!
Old Feb 10, 2011 | 01:34 PM
BiG ChOr!Zo's Avatar
i use to run spc camber kits in the front and they did not leave any wear on my tires but they were poorly made since i had to grind them to fit and the bushings took a crap...im not using any camber kit now and my tires are still going good and this is on a 2.50F and 2.25R drop...!!!
jdmeg6honda
Suspension & Brakes
Apr 16, 2011 10:25 AM
jdmsir4dr
27
May 9, 2010 06:29 PM
ef-b16sedan
19
Mar 29, 2007 06:12 AM
sherfield2002
Oct 29, 2004 08:43 PM
