gsr crank/rods in lsvtec?
with some arp rod bolts and stuff you could definitely rev it a lot higher the gsr crank is very well balanced crank. other then that there's not much to gain from this.
Use the LS crank and rods and just pick up a set of new high comp pistons or a used set of pr3s
heres a good thread u should read. https://honda-tech.com/forums/forced-induction-16/gsr-crank-vs-ls-crank-ls-vtec-turbo-1395196/ main thing with ls vtec swaps is to make sure u get arp rod bolts to help take the higher revs. gsr revs alil more happy with the shorter stroke but u gain more tq from using a ls crank. goodluck
wont the gsr rods lower the compression too much... i may be wrong but im pretty sure thats what a compression calculator showed me when i was looking into a lsvtec
RTW DC2R
Apr 24, 2004 10:39 AM
