FS: Peakboost/Garrett GT40 Blowzilla Turbo
It is a Peakboost/Garrett T3/GT40 Turbo. "Blowzilla" (SC61) .70 A/R, 61mm Inducer. Stage 5 Turbine Wheel. Ball Bearing. .63 Hot Side. Has the same compressor housing as a GT35R. Flows at 65 lbs/min.
Turbo made 325whp at 10psi on a stock GSR with 9:1 compression, stock rods, stock bore, stock head and cams, with upgraded valve springs.
Looking for $800. Can throw in oil restrictor fitting, return fitting, 4 bolt downpipe flange, and maybe a BWR Purple battery tie at this price.
PM, Call/Text 902-790-3941 or Email 081041v@acadiau.ca
Only reason for selling is that I am thinking of going a different route. Turbo has no shaft play and has low kms on it. Use to belong to a friend who only put 5000 miles on it and babied it.
xtremeness101
Jul 24, 2005 07:47 AM
