really wierd problem someone please tell me what it is.
Old Sep 25, 2002 | 07:12 AM
XEF-9X's Avatar
Default really wierd problem someone please tell me what it is.
yesterday my car was running perfect. and then i got to my gf's house and shut the car off. and then i started and i was driving and it wouldnt go over 3500 and the exhaust would go pop pop pop and the engine wouldnt go over 3500 and it would almost feel like i was hitting fuel shut off. i turned my car off andback on again and the problem was gone. any ideas?
Old Sep 25, 2002 | 07:15 AM
ricodemus's Avatar
Default Re: really wierd problem someone please tell me what it is. (XEF-8X)
ecu went into limp mode for some reason. happened to me once, hasn't happened again.
Old Sep 25, 2002 | 07:20 AM
Perfectionist's Avatar
Pull the distributor cap off and see if the screw for the rotor came loose.
Old Sep 25, 2002 | 08:31 AM
Stupid Ass's Avatar
Default Re: really wierd problem someone please tell me what it is. (Perfectionist)
Ya that **** happened to me... I was like, hell if your going to blow up... than do it now... So I slammed on the gas and that little bastard started working fine. It was wierd because I pulled over and pulled sparkplug #3 out, and when I did that the car went into limp mode and would shoot a long code 1... but it wouldn't do it with any of the other plugs... wierd...
Old Oct 5, 2002 | 07:57 PM
PnX-R's Avatar
My instructor once told me that if your ignition coil is starting to go bad. One of the symptoms will the be car not going over a certain speed or rpm. Thus causing the popping from the exhaust.. Hope that helps..
Maldito X
25
Nov 20, 2006 04:37 AM
buzlink
Dec 29, 2005 08:45 PM
Tad
20
Dec 18, 2004 06:11 PM
Tad
Dec 18, 2004 05:20 PM
8200RPM
May 11, 2004 08:01 PM
