Distributor O ring leak
Old Sep 25, 2002 | 07:01 AM
RTW DC2R's Avatar
Default Distributor O ring leak
I replaced the O ring with a new ring, and it still leaks. Is there another O ring I can use to fix it? Any suggestions?
Old Sep 25, 2002 | 07:10 AM
JPP's Avatar
JPP
Default Re: Distributor O ring leak (Type Rizzle Fo' Shizzle)
What does it leak ?
Do you mean that moisture can get in the distributor cap ?
You could always try high temp liquid gasket (the same stuff used on the valve cover gasket to seal the corners).
Old Sep 25, 2002 | 07:21 AM
Willard's Avatar
are your sure the oil is coming from there?
Old Sep 25, 2002 | 07:53 AM
Ricky Rojales's Avatar
Sure it's not your head gasket?
Old Sep 25, 2002 | 07:55 AM
RTW DC2R's Avatar
Default Re: Distributor O ring leak (Willard)
I replaced the O ring with a new ring, and it still leaks.are your sure the oil is coming from there?
well it appears to be coming from there. it looks like its coming from that area behind the distrib cap, and leaking down to the front left of the head gasket. Its really hard to tell if the head gasket may be leaking as well, but I have already had the bottom end decked, and the bottom of the head smoothed out. They found .003 inch variance in the left side of the head, that they were supposedly able to correct, but cant go much more because im running CTR pistons and clearance will become an issue.
Old Sep 25, 2002 | 08:05 AM
JPP's Avatar
JPP
It could be the valve cover gasket leaking from one of the corners in that area. You could remove the valve cover and inspect the gasket to see if its not damaged.
I doubt it would be the head gasket leaking oil
hugodc2
Nov 1, 2015 08:10 PM
Bradsxx7
May 30, 2009 10:33 PM
lv6l
14
Mar 8, 2009 11:14 AM
fujiwara takumi
Jul 29, 2006 12:26 PM
B18C-VTI_R
Jul 13, 2004 01:23 PM
