Please help asap brake fuse keeps blowing
Old Feb 7, 2011 | 10:31 AM
Teg4u's Avatar
Default Please help asap brake fuse keeps blowing
Hello I searched around on the forums and got a lot of info but i still can't get it to work so
-Problems
my brake/horn fuse keeps blowing out
when the fuse actually doesn't blow sometimes which is rarely, it messes with my left turn signal-it makes the bulb just stay constantly on
-when i don't have the brake fuse in the left turn signal blinks a different speed then the right side and when it blinks it takes power from the whole car like the idle moves with the blinker and all interior lights blink with the blinker
things i have done-
-replaced bulbs
-unplugged both rear taillight harnesses-still blows
-removed turn signal fuse/all headlight fuses-still blows
-unplugged all headlight harnesses-still blows
-checked wires all around and still haven't found the short
i haven't touched anything on the car or messed/fixed anything recently
everything did work fine before so idk how this came up
please help this is a 94 integra, the engine bay is wire tucked, but remember everything worked fine before
Old Feb 7, 2011 | 04:04 PM
fcm's Avatar
fcm
Old Fart
Default Re: Please help asap brake fuse keeps blowing
Sounds like you have a short between the brake light lead, green/white and your left turn signal lead, green/blue.
When you say, "it messes with my left turn signal-it makes the bulb just stay constantly on" what bulb(s) stays on, The left indicator, the left front signal, the left front side marker, the rear left signal lights. or all or some of the above? 94
Old Feb 7, 2011 | 09:45 PM
Teg4u's Avatar
sorry actually mean my right side, but its the actual rear bulb and indicator in the cluster that stays lit
Old Feb 8, 2011 | 05:39 AM
fcm's Avatar
fcm
Old Fart
So the front signal and side marker do not stay on? 94
Old Feb 8, 2011 | 10:24 AM
Teg4u's Avatar
i don't have a side marker and the front turn signal isn't there in the first place, previous owner cut it out, don't ask me why maybe he was a dumb-A
but it worked fine even without the front one
Old Feb 8, 2011 | 04:49 PM
fcm's Avatar
fcm
Old Fart
You have no front signal lights??? 94
JPelto
Jul 26, 2014 06:13 PM
b18c1vtecdc2
Sep 2, 2013 09:31 PM
jasrams
Honda Civic (2001 - 2005)
Jul 10, 2012 12:13 PM
hondaman177
Nov 8, 2007 01:08 PM
Bobby808
Apr 10, 2005 11:13 AM
