dash instruments going crazy car driving weird
Old Feb 7, 2011 | 08:04 AM
rudyndrew's Avatar
Default dash instruments going crazy car driving weird
Another damn problem guys. It was koo for awhile and now after the game I went to start the car and noticed that the gas needle wasn't working and my radio neither and my signal blinkers were on. I keep hearing click noises from the dash like the main relay side and from the glove box side. It made my headlights dim really low. My battery is a new optima and everything seems to be functioning koo under the hood so what can it be??
Old Feb 7, 2011 | 08:06 AM
fleabag's Avatar
Default Re: dash instruments going crazy car driving weird
You can't seriously be asking this question, it's almost as if you know exactly what's wrong... Check the main relay! Duh!
Old Feb 7, 2011 | 08:16 AM
rudyndrew's Avatar
ill check it just wanted to see if it can be some other electrical problem since I've been having plenty of those in the past but ill switch it out with my buddies relay and go from there.
Old Feb 7, 2011 | 08:32 AM
fleabag's Avatar
If you had a multimeter, you could test all the electrical relays and dealing with this issue would be a million times easier.
Old Feb 7, 2011 | 09:27 AM
ZCSp0ngeR's Avatar
i would check your grounds, i had the same problem, the valvecover ground was getting hot as heck, switched it never had the problem again
Old Feb 7, 2011 | 10:01 AM
rudyndrew's Avatar
Change the relay still the same all shakeup really bad and some gauges still not working and signal lights on the cluster still stay on
Old Feb 7, 2011 | 10:05 AM
fleabag's Avatar
weak ground to various places. When you picture a "ground" you need to look at the entire picture. In the case of an O2 sensor, the part where the o2 sensor screws, the bolt that meets the block and the exhaust manifold, and the eye hole where the bolt touches the exhaust manifold in order to hold it against the block. Your o2 sensor uses the exhaust manifold as a ground for its signal, yet this is a commonly overlook area when dealing with poor fuel economy or o2 sensor issues. If you don't understand what I'm getting at, what I'm saying is that don't worry JUST about the part where the ground screws in, but make sure that the whole path to ground is good as well.
Old Feb 7, 2011 | 10:43 AM
rudyndrew's Avatar
Icon2 Re: dash instruments going crazy car driving weird
Ill check that right now then
Old Feb 7, 2011 | 12:18 PM
NotoriousCRV's Avatar
im in on this one Im having the same problem! Ive checked all grounds and still nothing either
Old Feb 7, 2011 | 12:52 PM
fleabag's Avatar
don't just stare at it.. eat it!
Old Feb 7, 2011 | 01:05 PM
rudyndrew's Avatar
koo its all good now. got a flat screwdriver and started scraping the ground wires and where they sit so that they would be clean of corrosion and went to start it. its even smoother than before and to think that i was gonna tow it for 60 bucks and who knows what. thanks alot guys.
Old Feb 7, 2011 | 01:07 PM
rudyndrew's Avatar
thats the ground that looked really bad that i paid most attention too.
Old Feb 7, 2011 | 07:02 PM
efjones9's Avatar
check the ground on the thermostat and the main battery ground.
Old Feb 9, 2011 | 06:47 PM
thats awesome! Funny thing is I fixed mine today also it was my valve cover ground I just attached it to where the AC bracket originally went.
Old Feb 9, 2011 | 08:00 PM
theft24's Avatar
valve cover grounds are garbage anyway, i always ground to the head or block can never go wrong there
Old Jun 2, 2015 | 12:56 PM
emado's Avatar
thank you very much guys you were so helpful after all the trouble I went through it was only lost connection in the battery groundthank you again have a good one😃😃😃😃😃
wrx2civic
15
Jan 24, 2009 12:42 AM
youdontneed2cams
Dec 3, 2007 09:08 AM
EF_ST@TUS
21
May 10, 2007 09:45 AM
monalisa overdrive
Jun 16, 2004 10:11 PM
I Want An Si
Jan 25, 2004 09:06 PM
