MPH JUMPING on Speedometer?? PLZZ HELP!
Old Feb 6, 2011 | 10:22 PM
ej2kiid's Avatar
Default MPH JUMPING on Speedometer?? PLZZ HELP!
whats sup hondatech
ok i got a problem with my eg which i will explain as clear as i can!
* when i start my car of course the speed is at "0 mph".... ok now when im driving lets say 20-30mph the tach is still at zero and lets say i go a bit faster my tach jumps all the way to 120mph and when i slow down it goes for 120mph and up so basically my needle goes from zero all the way around to zero again.. idk if i expalained myself but i really need some help on this! thanx
plz no negative comments i just want to fix this asap! it gets annoying "seriously"
Old Feb 6, 2011 | 10:23 PM
ej2kiid's Avatar
Default Re: TACH JUMPING?? PLZZ HELP!
anyone know... i know some of you might say its the vss but its not becuz i replaced it
Old Feb 6, 2011 | 10:35 PM
ricky00's Avatar
change out ur speedo ic or buy a new cluster
Old Feb 6, 2011 | 10:36 PM
Ryank327's Avatar
Well if you have MPH on your Tachometer then something is definitely and seriously wrong.
But seriously, sounds like the actual Needle/gauge is broken. Probably would be easiest to just swap in a whole new(used) cluster.
Old Feb 6, 2011 | 10:55 PM
ej2kiid's Avatar
i had a feeling it could be the cluster
ej2kiid's Avatar
i will change it as soon as i can find another cluster hopefully its that
Old Feb 6, 2011 | 10:56 PM
ej2kiid's Avatar
i will try to make a video of what im talking about
Old Feb 7, 2011 | 05:17 AM
Former User's Avatar
Is this a tachometer or speedometer problem?
Old Feb 7, 2011 | 05:38 AM
ej2kiid's Avatar
speedometer.... my rpm gauge works fine but the speed doesnt
Old Feb 7, 2011 | 05:50 AM
ciaran_mo's Avatar
if its not the VSS its the wiring towards it. happened my car, and after months of testing, it was the loom at fault. hope this helps
Old Feb 7, 2011 | 06:24 AM
Sonia's Driver's Avatar
Is this a manual or automatic transmission? Please post the year of the car.
It could be the three things that have been identified: Speed Sensor (VSS), wiring, Speedometer.
One option for troubleshooting: get a multimeter with gator clip wires, put the car up on jackstands, disassemble the dash to get to the speedometer, clip the multimeter leads onto the wires going into the speedometer, run the car at various speeds. (HOLY CRAP, MAKE SURE THAT THE WHEELS ARE OFF THE GROUND AND THE JACK STANDS ARE SECURE.) If the signal from the VSS is correct, the speedometer is bad. If it is not correct, clip on to the output from the VSS and check that. (You will need an assistant to press the accelerator pedal.) If the signal is correct, the wiring harness is bad.
Good Luck
Old Feb 7, 2011 | 06:31 AM
Default Re: MPH JUMPING on Speedometer?? PLZZ HELP!
Thread title fixed.
Old Feb 7, 2011 | 06:56 AM
sextav6's Avatar
The other day I started my hatch and the needle on the tach was actually flipped and was hanging at the bottom, and when I revved up it was going 'up' but counterclockwise as opposed to the typical rotation of the needle. very weird, however, once it warmed up it reverted to its normal course. not that this helps of course, just throwin it out there
Old Feb 7, 2011 | 07:59 AM
92lxsleeper's Avatar
use search cause i see this question all the time. its either one of two things, the cluster or the VSS. how to tell?
do you have a check engine light?
If yes its the VSS
If no its the cluster.
Old Feb 7, 2011 | 11:38 AM
ej2kiid's Avatar
ill check that out today
thanx
Old Feb 7, 2011 | 11:39 AM
ej2kiid's Avatar
Good Luck
95 civic dx coupe manual transmission
ej2kiid's Avatar
Thread title fixed.
thank you
Old Feb 7, 2011 | 11:41 AM
ej2kiid's Avatar
mines does the same it hangs but doesnt go back to place it goes crazy
ej2kiid's Avatar
If yes its the VSS
no check engine light
im looking for a ex/si or sir cluster asap
Old Feb 7, 2011 | 01:24 PM
CivicSi95's Avatar
when you changed out your VSS, did you replace that little metal rod as well?
Old Feb 7, 2011 | 05:11 PM
ej2kiid's Avatar
yea the whole thing
im looking for a cluster
Old Jul 14, 2011 | 11:56 AM
lickatonge1's Avatar
My tach used to jump from 0 to 3 or 4000 rpms, and while driving the spedo would do the same. Now tach is completely dead. And only when i first drive off in the morning the spedo works for a few minutes then goes dead. It isn't the dizzy or vss. Both are showing readins on the diagnostic. So i'm now gonna swap clusters and see.
Last edited by lickatonge1; Jul 14, 2011 at 11:57 AM. Reason: wrote tach instead of spedo
Old Jul 14, 2011 | 12:24 PM
97slvrhatch's Avatar
same thing happend to my car
muddmonky
Oct 21, 2012 06:14 PM
Type_D
Jan 5, 2010 03:15 PM
pumafeet10
Mar 5, 2008 04:51 PM
Ding
10
Apr 25, 2006 10:51 AM
rev210k
Jan 31, 2006 05:19 PM
