Timing help
Since I have installed a new head gasket in my 1995 Civic with the 1.5L non v-tech engine I cannot get the timing belt to align. It seems like I am off by a half a tooth. And the ignition timing will not set properly, its like I cannot turn the distributer enough... I have spent MANY hours working on this, any thoughts?
Btw when setting the ignition timing remember to jump the service connector under the dash.
The last step in the installation of the timing belt is placing it over the cam. An on this last step, make sure there is minimal belt slack on the left side as you face the cam and crank.
Thats where the problem comes in.... When I am placing the belt over the cam gear, and it has minimal slack, it seems to be about a half a tooth off... So to get the belt to fit in with the gear, it comes out off..I guess I just need to keep playing with it.
b00st Junkie
Jul 24, 2010 07:29 PM
chromeBuddha
Aug 4, 2008 12:43 PM
