H22 swap what about injectors?
Old Feb 6, 2011 | 08:03 PM
Brownjd's Avatar
Default H22 swap what about injectors?
just wondering if there is any issues i will have with the injectors. I am converting from obd2 to obd1, do i need to dump the resistor box or just use the obd1 injectors? do i have to cut the harness and add the obd1 clips?
Old Feb 7, 2011 | 02:00 PM
GhostAccord's Avatar
Default Re: H22 swap what about injectors?
OBD1 H22 Injectors are peak & hold (low impedance) therefore they also use the resistor box. No need to remove it. As for the injector clips, I can't remember if they need to be swapped or not. I don't think they do, but someone else will have to chime in to confirm/deny that one.
racerguy101
Apr 22, 2010 10:09 PM
.BigSexy
Mar 21, 2008 02:39 PM
xXSilentScreamXx
Jul 18, 2007 05:46 AM
nos_b16
May 26, 2003 03:55 PM
