how to install 34.3mm freeze plug?
Old Feb 6, 2011 | 06:53 PM
Charlie Moua's Avatar
Default how to install 34.3mm freeze plug?
So I spent $0.94 at autozone for a Dorman 34.3mm freeze plug.
This will replace my stock charcoal canister in the back of the block.
My question is how to install it. It's a nice tight fit, I'll have to use a rubber mallet to tap it in the hole.
Q:
1) do I need to use any kind of sealer to make sure it doesn't leak?
2) do I have to worry about it popping out after install?
TIA
Old Feb 6, 2011 | 06:59 PM
90blackcrx's Avatar
Default Re: how to install 34.3mm freeze plug?
No and No, just tap it in with a rubber mallet
Old Feb 6, 2011 | 07:17 PM
NVturbo's Avatar
O.G. triple O.G.
....better make sure the cylinder head (vented valve cover) has plenty of ventilation.
Old Feb 6, 2011 | 07:30 PM
yes i have a two -10an male fittings welded on.
thanks - charlie
TomCat39
22
Mar 14, 2015 05:50 PM
noood
Apr 20, 2008 07:46 AM
riceball777
Jan 4, 2006 12:24 PM
tegedrex
Aug 24, 2004 05:17 AM
