h22 swap in 96 accord
Old Feb 6, 2011 | 04:43 PM
b17itr's Avatar
Default h22 swap in 96 accord
well, i finaaly got the h22 in my 96 cd7. finished wiring but got question on p/s bracket and alternator bracket. i tried using 96 accord but clearance issue. the h22 is a 95 do i use the 95 brackets or do i use later 97 h22 brackets.. it finaalt stop snowing in jersey so i can get back to my swap... hope someone can help i tried search but nothing on the year for brackets to use thanks peeps..
Old Feb 6, 2011 | 07:11 PM
Brownjd's Avatar
Default Re: h22 swap in 96 accord
which crank pulley u using? should be able to use accord alt bracket. My H22 is a 97 and the p/s bracket works fine. Im doing this swap this weekend in a 96 cd5, any advice?
Old Feb 7, 2011 | 05:24 PM
b17itr's Avatar
i'm using h22 pulley- i think i'll just use the 95 brackets and play around with the p/s pump. i had this swap in my 88 lude inx before. my advice before u install the motor- make sure u have all wiring harness done, modify fuel rail and make sure u dont have the rear engine mount on while getting it in... u need all the rrom when putting it in.
Old Feb 7, 2011 | 05:58 PM
nus_dogg's Avatar
On my setup, I went with the F22 A/C bracket to retain my Accord's A/C compressor. As for Power Steering, I got myself a 97+ Prelude Power Steering Bracket, so I can retain my stock F22 Pump and Line w/o customizing anything. I used the F22 Crank Pulley I believe; can't remember but they both work.
Dr. D-Series
Feb 25, 2013 07:10 AM
accordmatt
Jan 3, 2011 11:28 AM
accordmatt
Jan 3, 2011 08:53 AM
Accord4Sure
Aug 19, 2005 09:41 AM
jaosnwallace
Jan 16, 2003 03:19 AM
