1992 Honda EG weird idle on hot days with aircon on
Old Feb 6, 2011 | 04:12 PM
drgtr's Avatar
Default 1992 Honda EG weird idle on hot days with aircon on
Airon works fine on hot days.
Just on hot days when im idling with aircon on the idle seems to go from 900rpm to 1400 rpm every 4 seconds or so. Is this from the radiator fan kickin in and out or the compressor in and out?
Only happens on really hot days with the aircon on. Normal warmish days aicon on. Idles fine.
Honda EG Civic with B18c7.
Standard no mods.
Old Feb 6, 2011 | 07:03 PM
pwebb0207's Avatar
Default Re: 1992 Honda EG weird idle on hot days with aircon on
did you recently disconnect a battery cable or have to jump it?
Old Feb 6, 2011 | 07:07 PM
87 SiviK Si's Avatar
That's the compressor engaging/disengaging. The you definitely feel the strain of the compressor in our little motors.
Old Feb 7, 2011 | 01:04 PM
drgtr's Avatar
WHy on really hot days does it engage/disgage more?
drgtr's Avatar
No. Not at all. Car has been trouble free.
Old Feb 7, 2011 | 01:14 PM
Former User's Avatar
I forgot that it's winter here and summer in Sydney.
Does the condenser fan fail to turn on when the compressor clutch engages?
Ryank327's Avatar
Cause on hotter days the motor must work harder to produce the same power.
Try doing an idle relearn and it might solve it. If not I wouldn't worry too much.
disconnect your negative battery terminal for 5 minutes
Make sure all electrical items are turned off.
Start the engine. Hold the engine speed at
3,000 rpm with no load (in Park or Neutral) until
the radiator fan comes on(you'll hear it).
Let the engine idle for about 5 minutes with the
throttle fully closed and with all electrical items
off.
Old Feb 7, 2011 | 04:51 PM
drgtr's Avatar
off.
Yes Aircon Condensor fan kicks iin perfectly as it should.Just weird seeing that idle. Aircon is cold too. I will probably ignore it,. Thanks for the instructions
Old Feb 7, 2011 | 05:11 PM
The behavior of the A/C and idle speed is not normal. Hook up a manifold gauge set to check the high and low side pressures. It's possible the system is overfilled with refrigerant.
Old Feb 7, 2011 | 11:09 PM
drgtr's Avatar
Thanks Ron. How do you know so much about these hondas? Are you a mechanic or tuner?
Old Feb 8, 2011 | 09:04 AM
AlexBerg's Avatar
Yeah sound like a its over filled... if its really hot where ur living ur gauges should be at 30/35 on low side and about 150 ish on high side... being to full will make ur compressor clutch Come on and off A LOT and the car will idle like crap and almost seem as if its bogging out.
award78
Honda CR-V & Element
11
Sep 12, 2022 02:24 PM
gpuck16
Honda Civic (2001 - 2005)
Aug 17, 2018 12:31 PM
ed_hdz
Apr 8, 2012 06:30 AM
Katastrophic
Aug 27, 2011 09:23 AM
KB96VTEC
Jul 31, 2008 06:58 PM
