help!!! engine wont start, will turn over...
Old Feb 6, 2011 | 01:59 PM
1994turbocivic's Avatar
Default help!!! engine wont start, will turn over...
hi, i have a 94 civic with d16z6... engine will not start, starter is working, battery is charged, fuel pressure is good 40psi. i have checked, i am getting spark at plugs, i just dont know if its enough. any help would be gladly appreciated, thanks ahead of time!!!
Old Feb 8, 2011 | 06:50 PM
Default Re: help!!! engine wont start, will turn over...
anyone, any tips or help??? if you need info on motor or setup or things ive tried just ask... thanks
Old Feb 9, 2011 | 02:55 AM
wshuculd's Avatar
change your igniter
Old Feb 9, 2011 | 05:01 AM
my igniter??? you mean the dizzy or distributor... i seem to be getting spark bbut i dont think its enough... wouldnt it still start tho even if i had low spark?? it doesnt even sound like it is gonna start..
Old Feb 9, 2011 | 05:12 AM
wshuculd's Avatar
You can change the dizzy or just the igniter.You'll still get some spark but it wont start itll just turn over
Old Feb 9, 2011 | 06:07 AM
fcm's Avatar
fcm
Old Fart
As mentioned, if you have a weak spark check the ICU, [igniter] and the coil, also check spark plug leads, the cap and rotor... http://www.ht-archive.com/showthread.php?p=10136469. 94
Old Feb 10, 2011 | 06:26 PM
ok thanks alot!! i will change the distributor and rotor. i have a msd external coil... is there any way i can check if it is still good???
Ashley Shults
Nov 14, 2016 09:51 PM
2.2lude88
Jul 3, 2006 05:21 PM
keng
Jul 6, 2005 07:27 AM
Big_b_69er
Jan 24, 2002 09:07 AM
HYBRIDGSiR
Nov 23, 2001 07:32 AM
