1995 civic ex stripped valve cover bolt holes?
Old Feb 6, 2011 | 01:01 PM
sleeper98civic's Avatar
Default 1995 civic ex stripped valve cover bolt holes?
So I Just bought a 1995 civic ex with the stock d16z6 and notice I had a pretty dececent valve cover leak, so I decided to take the valve cover off to see what else was going on under neath and when I went to put the cover back on I noticed that only 2 of the 4 bolts would actually thread on. One side of the bolt holes is broke off some where. Is something like this even repairable and worth doing for the $$ or should I just swap it out for another engine? It has about 205k on the engine, has a pretty good front main seal leak and will need a new timing belt and water pump.
Old Feb 6, 2011 | 01:28 PM
apexi_rsx's Avatar
Default Re: 1995 civic ex striped valve cover bolt holes?
shame the head looks pretty clean i would try to see if u can find another cam cap for it.
Old Feb 6, 2011 | 01:52 PM
fonkernuckle's Avatar
^ or if unable to find cam cap and If it was my only car I would compression test the cylinders if readings were still decent I would swap the head, HG,good time for new t belt,water pump, front main seal and if it were my 2nd or daily car and comp numbers not too good I would clean the area put a blob of J*weld drill and tap it for the valve cover bolts and put a new t belt and front main seal on there although this does not sound like the best solution
Old Feb 6, 2011 | 02:53 PM
NotAJDMFanBoy's Avatar
JB Weld is strong, and could work. All those bolts have to do is keep the valve cover on.
You could just run a decent bead of RTV silicone around the valve cover and hopefully the two bolts will hold it down to dry. DON"T OVER TORQUE THEM! I think its supposed to be like 7ft lbs or something, it's basically threading the bolts in by hand and just snugging them a little with the wrench.
Old Feb 7, 2011 | 03:42 AM
Definitely going to try sourcing down a cam cap first!
A compression test is a must do! As long as the comp is good then it should be worth trying to fix/repair one way or another.
JB weld has gotten me out of a jam more than a couple of times!! Its last resort but better than nothing.
bck15
Nov 29, 2017 03:07 AM
cheenoadam
May 28, 2017 12:27 PM
anarchyfox
May 7, 2004 07:39 PM
Crimson490
May 3, 2004 08:21 AM
HarryB
Sep 6, 2002 09:29 AM
