Diagnosis Help Needed! Window motor
Old Feb 6, 2011 | 12:53 PM
pwebb0207's Avatar
Default Diagnosis Help Needed! Window motor
Installed new front door speakers. after putting it back together the passenger window wouldn't roll up.
Check for power - I am getting voltage to the motor connector using the master switch and passenger door switch. so I at this point it seems like I have a bad motor ... but I've never seen window motors suddenly crap out like that. It was fully functional just a few minutes prior.
So I apply direct power to the motor and it works ???? I am able to operate the window up and down but for some reason the vehicle cannot.
I am stumped. so far this system tests out okay.
I need wiring diagrams. Need to check my harness continuity. Anybody gots?
Old Feb 6, 2011 | 09:13 PM
KielJG's Avatar
Default Re: Diagnosis Help Needed! Window motor
You have a bad ground in the harness going to the door. The wire is probably just cut slightly, it's very common on these cars, I fixed a ton of them. Pull back the rubber cover on both door looms and check for damaged/broken wires, you won't even need the wiring diagram you can just repair them one at a time (there will most likely be a few that are damaged).
gr_elvis
Honda CR-V & Element
Apr 26, 2018 07:15 AM
Ek97hatch
12
Aug 18, 2017 06:53 AM
scclark
Aug 29, 2016 05:38 PM
ek9800
Dec 20, 2004 05:00 PM
funkylemons
Audio / Security / Video
Nov 27, 2002 10:50 AM
