Buzzing sound abs light
Old Feb 6, 2011 | 05:47 AM
Steve LeB's Avatar
Default Buzzing sound abs light
When I start my car there is a loud buzzing noise comming from unde rthe hood on the drivers side. After it stops the abs light comes on. 1997 accord 4cyl. any suggestions.
Old Feb 6, 2011 | 08:09 AM
poorman212's Avatar
Default Re: Buzzing sound abs light
I'd start with checking the brake fluid level in the abs unit.
If that is fine then I would get the codes.
Old Feb 6, 2011 | 08:38 AM
nus_dogg's Avatar
I hate ABS; takes up soo much room.
Old Feb 6, 2011 | 12:23 PM
Steve LeB's Avatar
How do ypu add fluid to the reservior
Old Feb 6, 2011 | 05:16 PM
phootbag's Avatar
You probably have an over-run DTC due to a low fluid level as a result of a leaking ABS accumulator o-ring.
Old Feb 7, 2011 | 05:02 PM
poorman212's Avatar
using my 95 as a ref...Black, quater size rubber plug on abs unit, under that is a clear plug-remove it. Fill, Slowly, till at the Max mark on res.
exactly what I was thinking........
Old Feb 7, 2011 | 05:16 PM
shortlid's Avatar
Do all Honda ABS units have this or just the early ones.
Old Feb 10, 2011 | 07:40 AM
newshocker's Avatar
Mine does the same thing. I have a 94 accord ex and it will make the buzzing sound, then after about 10-15 seconds it quits, the light comes on and the noise stops.
Old Feb 10, 2011 | 09:20 AM
h22a2JZGTE's Avatar
i have the same problem as well...if it wasnt such a hastle..id just take the whole damn system out lol
Old Feb 10, 2011 | 09:32 AM
djkurious's Avatar
Did honda ever redesign that ABS pump? Mine does the same thing.
I also did all the troubleshooting mentioned above.
Old Feb 10, 2011 | 02:32 PM
phootbag's Avatar
I swear...
Old Feb 10, 2011 | 02:55 PM
TranceAddicts's Avatar
mines does the same
Old Feb 10, 2011 | 02:58 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Originally Posted by TranceAddicts
mines does the same
uses0ap
Mar 8, 2009 07:45 PM
rickyh22
Oct 9, 2007 03:00 PM
Vagabund07
Oct 7, 2007 06:06 PM
Rhood
Mar 14, 2007 12:30 PM
KingJeff
Apr 29, 2002 05:08 PM
