Hondata s300 questions
Old Feb 6, 2011 | 05:24 AM
F!ip's Avatar
Default Hondata s300 questions
I have a Hondata s300 that came with my civic. I use this car for daily driving... and it is putting out around 360 hp. Is there going to be an advantage for me to get a laptop? Can you monitor how the engine is running through this if I get a laptop? Sorry for the stupid question, I am very new to this stuff.
Old Feb 6, 2011 | 12:32 PM
ej1_taffetawhit's Avatar
Default Re: Hondata s300 questions
It all depends.
First you have to learn how the S300 works. you can record what your engine is doing through you laptop.
Being new to this, you are more likely to make mistakes so read up first.
Old Feb 6, 2011 | 02:37 PM
mtber's Avatar
Get a wideband oxygen sensor gauge kit before you do anything...
Old Feb 6, 2011 | 05:39 PM
F!ip's Avatar
Okay. What is a good one to get that isn't really expensive?
Old Feb 6, 2011 | 07:04 PM
mtber's Avatar
INNOVATE MTX-L
Old Feb 7, 2011 | 06:17 AM
F!ip's Avatar
OK looks good. This is going to sound stupid, but here it goes: my friend said I don't need wide band because I am running 880 injectors. Is there any truth to that?
Old Feb 7, 2011 | 07:25 AM
HAMOTORSPORTS's Avatar
No, lol. He is completely wrong. You DEFINETELY need a wideband unless you are going to have it tuned by someone else who has a wideband. Even then, it's always nice to have one so that you can keep an eye on your A/F ratio's
Old Feb 7, 2011 | 03:26 PM
Sr420Det's Avatar
its already been tuned obviously or itd b running like crap or blown up by now if it hasnt. The wide band can be wired into the s300 so itl show what the motor as far as air fuel ratios. Sounds to me like u should just leave it alone but yes u can monitor all sensor on the laptop with the usb plugged to the ecu. U can also change ignition timing and fueling (along with tons of other stuff) and this is were u can screw up ur motor, so u shouldnt mess with any of the settings. Everything has already been set by the previous owner, i.e a tune.
Old Feb 7, 2011 | 03:30 PM
F!ip's Avatar
Originally Posted by Sr420Det
but yes u can monitor all sensor on the laptop with the usb plugged to the ecu. .
So, if I get a laptop, you are saying there is no need for any guages?
Old Feb 7, 2011 | 03:41 PM
Sr420Det's Avatar
yes but its only as good as ur factory sensors, like u wont b able to c fuel or oil pressure but u can c injector duty cycle, pulse width, throttle position, speed, rpm, ign adv, bar pressure, map, etc...
Old Feb 7, 2011 | 03:44 PM
Sr420Det's Avatar
or u could just get a tuner viewer
Old Feb 7, 2011 | 05:24 PM
Or even better, the Tuner View RD-1
http://www.hamotorsports.com/tunerview-rd1.html
Old Feb 7, 2011 | 09:03 PM
Sr420Det's Avatar
Damn and here i was thinkin the original was fairly new, nice! I want one!
Txdragon
Engine Management and Tuning
15
Apr 11, 2016 06:48 PM
mtber
24
Apr 16, 2014 08:09 PM
BoOsTiN Dc2
Aug 31, 2005 10:05 PM
fastludeh22
Sep 5, 2004 07:12 PM
PROFILES2000
May 23, 2002 12:49 PM
