98 GSR injectors in 95 GSR
Old Sep 25, 2002 | 04:33 AM
Projekt20's Avatar
Default 98 GSR injectors in 95 GSR
I just tried to install some 98 GSR injectors in my 95 GSR motor....I had H22 290cc injectors there before. Trying to swap some regular GSR injectors in there, cause I'm still breaking in the motor. I modded the plugs on the 98 GSR injectors and I got them to plug in. The problem is that the motor now fluctuates from like 4000rpms to 2000rpms at idle. I'm running a chipped P28 ECU now and when I had the H22 injectors it was idling real good. I don't have any codes. What could be wrong? Thanks
-Trung
Old Sep 25, 2002 | 07:04 AM
GraphiteAccord's Avatar
Default Re: 98 GSR injectors in 95 GSR (Projekt20)
those injectors were never ment to be put into that year of car. Does anyone ever research stuff anymore? 98 injectors are saturated, and i believe '95's are peak and holds. I don't think you shorted out the ECU...290cc prelude injectors? that means they are '97+, which also means they're saturated......
Old Sep 25, 2002 | 07:21 AM
rainmanEK's Avatar
big strong guy
Default Re: 98 GSR injectors in 95 GSR (GraphiteAccord)
i dont belive 95 gsr injectors are peak and hold, no resistor box unlike pre obd first gen b16s 91-down! eric
Old Sep 25, 2002 | 07:23 AM
dustin's Avatar
Your attitude is unnecessary because you are the one that is incorrect.
Anyways, 94+ integra injectors are all saturated. If you got them to plug in they will work fine. Your problem must be somewhere else. If the ECU is chipped to run 290cc injectors, you will need 290cc injectors in the car. 290cc is just the flow rate at 43psi fuel pressure... the ECU controls actual fuel delivery.
Try to reset the ecu. If the motor is freerevving up to 4k rpm, the problem is definately not with the injectors. Check IACV wiring or a vacuum leak the size of your fist......... Or is your idle just surging?
Dustin
Old Sep 25, 2002 | 08:51 AM
1.8T_EG's Avatar
... also, try retarding your timing... i used to run a mugen chipped p72 when i was all-motor and i had to retard timing on the distibutor because the chipped ecu's timing was to advanced and the ecu ((in closed-loop)) would try to compensate by dumping more fuel ((so that it wouldnt lean out))... just a thought... that is what i did to smooth out the idle...
Old Sep 25, 2002 | 08:58 AM
Kevin's Avatar
oooooo the irony! lol. You should do some research man.
[Modified by 5speedv6, 5:59 PM 9/25/2002]
Old Sep 25, 2002 | 02:34 PM
Projekt20's Avatar
Got the injectors working today.....turns out I forgot to put the big rubber gromet on the bottom of the injectors and had a mad vaccum leak. Works great now. Thanks everyone. And to Graphite....you just got OWNED!!!
-Trung
Old Sep 25, 2002 | 04:33 PM
TurboInteg95's Avatar
That was some pretty bad pwnage.
ice-burg-slimm
Oct 29, 2005 05:03 AM
toooslow
May 9, 2003 09:29 AM
Shoe
Jul 26, 2001 08:25 AM
