I guess Im retarded but help with Hasports wiring instructions
Hasport instructions ay with the wires facing away from you and then tell you location of the pins. That would put b19 in the place of b1 if you turn it around right?
Can I safely use this pic, since I almost had my **** bass ackwards??
Thanks for the help.
Monty
Monty
all i gots to say is hasport can kick my *** when its comes to wiring...ive had my multiport swap for almost a year and are stilll working out buggs!!
they can even wire up a tps without doing it backwards..found that last week
and i had to have a shop redo alot of the dizzy connections and mulitpoint connections cuz they would have fallen apart in 2 days.!
that pic is on point. look at the connectors from the side they are showing you (where the wires go into the plug). Remember that they count odds on top and evens on bottom.
Thanks!!
I got mixed up when the instructions tell you to hold the plug with the clip up and wires facing away from you. This is the first swap, fist time messing with ecu, so I wouldnt of known any better had i stumbled across this pic.
Hopefully I can get those damn pins out now....
BlackEG6
Oct 3, 2006 10:09 AM
tuname420
Welding / Fabrication
Jan 1, 2006 04:17 PM
