Del Sol Si E Brake help
So im new to the site. I just bought a 93 Del sol Si and i pull the ebrake all the way up and there is no tension and the car just rolls. So im wondering is how do i adjust it on a Si with disc brakes i see all these forums for drums but i need to know about disc brakes. Pictures help too
Im pretty sure there is a cable there i got under the car to where the cable comes threw the floor and hooks to the hydrolic lines for the disc brakes and there is a cable there.
you can try tightening it from the actual e-brake lever itself.... there is a 10mm nut that u can adjust or double check with another person underneath the car to se if the lines move when u pull on the e-brake lever.... because if the do thn there is the problem only the lines should move not the whole assembly... so if it will help i gotta do the same to my car and ill take some pics to help u out..
Did you have time to get it done or take pictures im still confused as to why mine wont work haha... every thing looks fine it just wont lock up the back wheels.
1sikhatch
Jul 16, 2009 03:06 AM
275Performance
Feb 8, 2004 06:56 AM
del type-r
Nov 2, 2003 07:04 PM
