Brake Question.. Need Help....
I have a 93 del sol with drum brakes in the back. I also have a set of integra rear trailing arms that i want to put on. My qestion is will the e-brake cable from the integra work with the del sol, or will i need to get an e-brake cable from a del sol with rear disc brakes. Any help would be great...
Re: Brake Question.. Need Help.... (del type-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del type-r »</TD></TR><TR><TD CLASS="quote">I have a 93 del sol with drum brakes in the back. I also have a set of integra rear trailing arms that i want to put on. My qestion is will the e-brake cable from the integra work with the del sol, or will i need to get an e-brake cable from a del sol with rear disc brakes. Any help would be great...</TD></TR></TABLE>
It should work without any trouble. I put the teg rears on my 93 hatch and the cables fit with little trouble.
Re: Brake Question.. Need Help.... (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote">most likely need the one for the del sol for proper fitment.</TD></TR></TABLE>
NO....... the Integra one will fit no probelm
Re: Brake Question.. Need Help.... (Navid OG)
to be safe get the ebrake cables from a del sol equipped with rear disk. but i've heard the only difference is that the integras is a 'tad' bit longer than the del sol. either way it will work. just need to route it so there isnt any slack hanging down
I know for a fact the the del sol's ebrake line is shorter. The integra will "fit" but they will be loose since they are longer. Whe I did my rear disc brake converion, I got the parts from a del sol, and they "fit" but I had to stretch it. Not all the metal clips were able to bolt on to the underside. I had to change the ebrake lines from a civic/integra. The del sol ebrake lines hook up under the car and are suspended in mid air by that middle bracket. The ones for the civic/integras mount inside the car right behind the ebrake handle.
424racer
15
04-25-2010 07:48 PM
94redintegra
12-25-2005 10:31 AM
275Performance
02-08-2004 06:56 AM
