D16y7 misfire
My ek misfires now when it starts up cold but goes away when it warms up alittle. I don't notice any miss's when it's warm what could cause this? Only new things are K&N filter and new pugs.
Ok I'll do wires first my bolts on my cap are oem and never been removed to when I went to take one off it broke right off and the rest seem to be doing the same thing. Do y7's hold up ok as long as I don't beat it and do oil changes and regular maitance?
I am asking because I have always owned b series swapped cars. And never had a factory sohc. Plus this is a y7 not the best engine Honda made compared to the z6 and y8. So I was wonder if the hold up as long as I know this is a DD and mot a race car. And don't rec the pi** out it will it last me. It currently has 104k
check the spark plugs, take pics if you don't know what they mean and then replace the spark plug wires if you haven't done so since owning the car since they should be replaced about every 30K miles.
Ok so I advanced my timing the whole way out on my distributer. And it idles perfect now. I do still have a misfire when cold thou. Is there anything bad about advancing my ignition timing? It runs fine and idles fine...
Interesting, hmm maybe you've got a weak or bad coil/ignition system? I mean think about it, if you have to advance the ignition timing all the way, then it's possible that before the coil wasn't firing by the time it was needed. I would replaced the bad ignition components because a weak spark that doesn't ignite the fuel mixture will mean unburnt fuel will leave, wasting fuel and will pollute the o2 sensor and catalytic converter. Just a bad idea to run the car like this.
Has your check engine like came on with a missfire DTC?? cuz it sounds like u got a problem wth your IAC valve... (Intake air control valve) They will feel just like a mis until the car is warmed up. Check the coolant in the car too... the iac is ran off of engine coolant.
Bruce_Leroy__
Oct 16, 2011 10:53 PM
ITRex
Jun 10, 2008 02:36 PM
