* NEPTUNE RTP/ P28 ECU COMBO PACKAGES * | HA Motorsports.com
As your Honda ECU specialist, we are proud to now offer our P28 ECU with Demon and Neptune RTP software packages for Honda-Tech members! [No software bugs like Crome, more features than Hondata S300 !]
Included in package:
* HA Motorsports FULLY RECONDITIONED P28 ECU specially prepared for use with Neptune
* Professionally installed brand new serialized Moates Demon unit
* Neptune RTP software license for tuning your new ECU package
* Fully assembled and tested before shipping for simple plug-n-play installation
Sale Price $549.00 USD
Click Here to Order from our Online Store >>
(pictured above with USB mounted internally. Available with external USB connection, or upgrade to bluetooth for $89 additional)
Neptune's RTP software interface: (screenshot sample)
Basic List of software features with this Package:
Beautiful 3D Beveled interface.
User Friendly Toolbars with the options you need most.
Real-Time Datalogging Of Sensor Data, Inputs, Outputs, and ECU Data.
On Board Logging With Lossless Compression To Allow 3 To 5 Times The Regular Amount Of Data To Be Recorded. Offers Up To 12 Hours Of Datalogging Time With Compression Enabled.
Datalog Playback, Save, and Export to CSV.
Datalog Trimming.
Datalog Commenting For Later Review or Sharing With A Tuner.
Graphing Of Sensor Information With Real-Time Values and Live Scrub (Dragging with mouse).
Live Graphing Of Real-Time Sensor Trends.
Direct Serial Logging From LC-1, LM-1, and LM-2 Products (LM-2 currently requires connecting hardware to allow legacy serial connectivity).
Map Trace and Lambda Trace.
24x24 Ignition and Fuel Maps For Precise Tuning.
Dual Tables For Low/High Boost, Different Fuels, or Alpha-N (ITB) Tuning.
Easy Injector Sizing.
Fuel Trims for Cranking, TPS Tip-In, Post Start, and Individual Cylinders.
Rev Limiter with Fuel Cut, Ignition Cut, or Both.
Rev Limits Per Gear.
Launch Control (2-step) With Anti-Lag.
Full-Throttle Shift.
Use The Check Engine Light As A Shiftlight With Different RPM Settings Per Gear.
Idle Adjustments for Idle Speed, Idle Speed vs ECT, and Idle Ignition Corrections.
Air Temp Corrections.
Water Temp Corrections.
Gear Based Fuel and Ignition Corrections.
Access To Many Other Stock Fuel and Ignition Adjustments.
PWM Boost Control With Simple, Boost By Gear, and Gear vs RPM Modes.
Quad Stage Boost Control.
Adjustable Prime Duration At Key On.
Overheat Protection.
Closed Loop Control With Selectable O2 Input, Conditions, and Wideband Support.
Anti-Theft feature requires inputs or a code to be entered with TPS and Brake pedal. Also has a valet/fallback mode with adjustable rev limit.
2 Multi-purpose Outputs With Fuel and Ignition Adjustments.
1 Multi-purpose Output With Multiple Output Settings Based On MPH.
4 Programmable Analog Inputs For Extra Sensors.
And A Lot More!
If you have any questions about our Neptune RTP/P28 ECU/Demon Package, please don't hesitate to PM or email us and we'd be more than happy to show you how this is one of the best OBD1 tuning systems on the market!
When you are ready to order, Click Here to purchase from our online store >>
HA Motorsports
www.hamotorsports.com
Datalog Trimming.
And A Lot More!
HA Motorsports
For those who want to avoid the extra wires, and also have the freedom to connect wirelessly to your new ECU package, we keep in stock the Neptune Bluetooth Module. This module is installed into the auxilary port of your Demon unit eliminates the need to plug into your laptop via USB
Only $89.00
Only $89.00Neptune Bluetooth Module
For those who already have a socketed P28 to use, we also offer our Demon and Neptune RTP License Package. This includes a new Demon unit, installation kit, USB cable, and one Neptune RTP software license for your new Demon. Can be installed into USDM and JDM ECU cases :thumbup
Want to run variable boost per gear? Need the most possible traction per gear? Our Neptune Boost Package has all of the great features of our standard Neptune RTP ECU package, but with the addition of PWM boost control and a MAC boost solenoid for complete boost per gear operation.
