O2 Sensor is bad- B16A OBD0-What should I Buy?
Old Feb 4, 2011 | 11:30 AM
blowingupjake's Avatar
Default O2 Sensor is bad- B16A OBD0-What should I Buy?
hey there,
Just went for emssion testing, passed with no problems except i need an O2 Sensor! so, I have the 89, PW0 Ecu, B16A(jdm duh) And am wondering what O2 sensors will be compatable? I'm hoping i can just go buy one for a del-sol or something? Help Please!
Thanks Very Much!
Jake
Old Feb 4, 2011 | 11:44 AM
Default Re: O2 Sensor is bad- B16A OBD0-What should I Buy?
Okay so i found the O2 Sensor i need, But just made a starteling discovery- there are no wires running to the O2 sensor on the header! WTF! I have no idea where the wiring is supposed to go.. I know to the ECU but other then that i'm so completely lost..
Old Feb 4, 2011 | 12:48 PM
4drEF's Avatar
Keyboard Humorist
More than likely your wire is there, but has been clipped from your harness.
Inspect the loom near the O2 and hopefully you will find the cut WHITE wire.
If not, then you can run a new one to C16
(Using this chart check the wire color going into the connector as well as compare the wire colors going to the pins around that pin so you are sure not mix up and pin incorrectly. I believe the connector images and numbers are as if looking into the connection side rather than the wire side.)
Old Feb 4, 2011 | 03:44 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
The O2 sensor you need is the same as the USDM CRX Si/DX O2 sensor. One wire unheated.
The PWO ECU needs 2 sensors to run right. One goes to C8 which you have to wire in because the USDM ECU does not have it. The other is C16 which is already in the harness. The sensors need to be close to the cylinder head, no more than 12" downstream from the head. They also need to installed and wired correctly.
Search here how to install them, I can't remember from the top of my head the order in which they monitor the exhaust gases.
Old Feb 4, 2011 | 04:30 PM
Wow. Thanks for the info guys! I'll be in the shop tomorrow going through the horrible wiring mess trying to find the White wire, And then it looks like i'm going to need to weld in another bung for the #2 Sensor. Man oh man. Thanks again for the help! I dont understand though, how all my emission numbers were so clean with out a working O2 sensor... weird right?
Jake
rage4theused
20
Jun 9, 2014 04:20 PM
quik89
Jul 24, 2004 03:40 PM
Ruby Civic
Jun 15, 2003 05:57 PM
