Who here has a distributorless ignition system?
Old Sep 24, 2002 | 10:51 PM
Tony the Tiger's Avatar
Default Who here has a distributorless ignition system?
I recalled seeing some guy posted some engine bay pics and it consisted a distributorless setup...that engine had torqoise coloured ignition wires. I believe someone told me that ITRinEJ sells these systems I remember correctly? Do I ring anyone's bell?
By the way, I am searching for a distributorless setup that will work with a Honda ECU, meaning no Motec, Electromotive, etc... Any inputs would be great.
Thanks
Old Sep 24, 2002 | 10:55 PM
Reid's Avatar
Global Moderator
Default Re: Who here has a distributorless ignition system? (Tony the Tiger)
MDI makes a distributorless ignition system.
Old Sep 24, 2002 | 10:56 PM
Tommy_Gunns's Avatar
I think Ben (AJ PWR) has one.
Old Sep 24, 2002 | 11:05 PM
SMSP's Avatar
I use electromotive but no ECU.
Old Sep 24, 2002 | 11:45 PM
AJ PwR's Avatar
Default Re: Who here has a distributorless ignition system? (Tommy_Gunns)
Yes i am running Ultra MDI. It made quite a difference. Same as I said before.... i loved response.
Old Sep 24, 2002 | 11:48 PM
Art Vandeleigh's Avatar
Default Re: Who here has a distributorless ignition system? (AJ PwR)
what are the benefits?? you are still using plug wires right?? so spark is still sent via wires?? what are the pros of this?
Old Sep 25, 2002 | 04:59 AM
Shark Tank's Avatar
Default Re: Who here has a distributorless ignition system? (up-youRs)
what are the cons of this as well? is the car daily driven?
Old Sep 25, 2002 | 05:58 AM
kungfuSiR's Avatar
What kind of ECU are you running?
[Modified by kungfuSiR, 9:58 AM 9/25/2002]
Old Sep 25, 2002 | 06:10 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Who here has a distributorless ignition system? (kungfuSiR)
:raises hand:
But mine was factory
Old Sep 25, 2002 | 07:30 AM
Bbasso's Avatar
Default Re: Who here has a distributorless ignition system? (Splat)
:raises hand:
Your word doesn't count, your not in an R=
Old Sep 25, 2002 | 09:24 AM
Kengs's Avatar
Tony,
Turquoise colored spark plug wires would be NGK Power Cables (I have them).
Ultra MDI is this:
Rob.
Sep 10, 2007 07:51 PM
BETO736
Jun 4, 2004 11:04 AM
DRKSol
May 22, 2004 11:33 PM
J2turbo21
17
Jul 28, 2003 02:10 PM
