DIY Front half bumper from scratch
Old Feb 3, 2011 | 07:21 PM
defcon's Avatar
Default DIY Front half bumper from scratch
So I decided I want to tackle on making a half bumper
I actually made video clips of what I've done and will post them later on after I make the edits.
This was my first time working with spackle instead of body filler. This was so easy to sand which allows me to see results quicker. One thing I learned was not to leave this outside because moisture will crack the spackle. So I moved it inside my garage and decided to work in there from now on.
I'm still reading the fiberglass forum archives to see if I can pick up any new tips on how to work with spackle.
Here's what i have so far taped up in green
1) fiberglassed the original shape of the bumper
2) i changed the shape of the mouth via cardboard
3) i added a lip on each side via cardboard
other designs i plan on adding on
1) modify the foglight housing area like my original version
2) add a horizontal bar to connect to the lip on each side
3) add some accents outside of the foglight area
1st mock up
added horizontal bar
horizontal bar reversed.
i figured that i can fiberglass this piece separately and just create black brackets for them
Final mock up.
fiberglassed and should be cured by tomorrow
I plan on making a master mold out of this in case I break this.
Pryed the half bumper off the OEM bumper
Left side with spackle. Bottom lip sanded down a bit
The cardboard strip will be beveled. Also like the middle piece wrapped around the mouth area.
I plan to wrap that specific area in cf vinyl
3/4 done with the spackle. The part that doesn't have spackle had to be refiberglassed
Moved the half bumper inside the garage to prevent moisture from cracking the spackle
Custom side skirts done. Ready for primer and master mold
Going on this bad boy
Old Feb 3, 2011 | 07:30 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: DIY Front half bumper from scratch
F
Old Feb 3, 2011 | 08:10 PM
02-type-s's Avatar
I think the kit thats already on it looks dope, what is it?
Old Feb 3, 2011 | 08:22 PM
BLANCOh22a4's Avatar
ruining such a nice car...
Old Feb 3, 2011 | 08:49 PM
defcon's Avatar
It's a type s replica kit. This is my daily driver kit. I plan to put the half bumper for meets and photoshoots
Old Feb 3, 2011 | 09:05 PM
Nate047's Avatar
Old Feb 3, 2011 | 09:15 PM
k7q's Avatar
k7q
badass!
Old Feb 3, 2011 | 09:29 PM
phatboycrxhf's Avatar
nice !!!
Old Feb 4, 2011 | 06:17 AM
switchjv's Avatar
is this part with the spackle going to be the actual bumper or the piece for the mold?
Old Feb 4, 2011 | 07:06 AM
defcon's Avatar
the spackle allows me to sand it smooth, create some finer lines that i cant do with fiberglass and to create some bevels. the stage that you see the bumper in right now is just the positive mold. once when im done detailing and sanding it, then i will make a negative mold out of it aka "master mold." then i can finally pull out multiple pieces from the negative mold/master mold.
bondo/body filler is just a pain to work with when it comes to sanding.
cryingsuns
Paint and Body
Aug 11, 2012 08:44 AM
defcon
Acura TSX
Mar 2, 2011 10:23 AM
brutekiller787
Jan 23, 2009 03:28 PM
B18ls*RAYON
Welding / Fabrication
Jan 16, 2005 07:58 PM
