problem with b20v turbo gears wont go in brake pedal stiff HELP
Old Feb 3, 2011 | 06:26 AM
em1effekt's Avatar
Default problem with b20v turbo gears wont go in brake pedal stiff HELP
i got my car tuned yesterday its a
b20v turbo with an ls transmision
everything was fine yesterday
today in the morning on the way to work i stoped at a red light
when the light turned green i tried putting it into first and it didnt
go into first or any of the gears
the car turns on...and it will go into the gears when the car is off
i tried putting it in first and the turning it on and it made a grinding noise and went forward so i turned it bak off and i also noticed the brake pedal is stiff and hardly goes down
what could this be?
Old Feb 3, 2011 | 06:51 AM
grumblemarc's Avatar
The Grumpiest
Default Re: problem with b20v turbo gears wont go in brake pedal stiff HELP
Slave cylinder. Happened to me last month. Replace it. Cost less than $20 and 15 minutes. Don't know about your brake pedal. But with that grinding noise let's hope it isn't more serious.
Old Feb 3, 2011 | 07:01 AM
sohctodohc's Avatar
i would do a slave and master cylinder. as if one usually goes out the other follows.
if it isnt that your clutch is shot
Old Feb 3, 2011 | 07:46 AM
Former User's Avatar
Clutch:
Is fluid low in the clutch master cylinder reservoir?
Is there a fluid leak at the top of the clutch pedal?
Brakes:
Check the brake booster and its vacuum hose.
Old Feb 5, 2011 | 11:58 PM
em1effekt's Avatar
turns out my clutch is gone (damn ebat clutch) xtd stage 3" lol
anyone know a good clutch for a fully built b20v turbo for a baller on a budget? lol
would an exedy oem be good?
Old Feb 6, 2011 | 02:32 AM
EsotericImage's Avatar
Retired Moderator
Im using an ACT 4 puck and holds everything i throw at it. about 85 bucks
Old Feb 6, 2011 | 11:28 AM
em1effekt's Avatar
85 bucks where?
Old Feb 6, 2011 | 12:51 PM
sohctodohc's Avatar
he probably is just refering to the clutch itself not a full kit with pressure plate and throwout bearing
Old Feb 6, 2011 | 02:47 PM
em1effekt's Avatar
yeah i noticed that....
having trouble finding a good clutch
Old Feb 6, 2011 | 08:01 PM
sohctodohc's Avatar
action clutch is what i have couldnt be happier with price and quality
Old Feb 6, 2011 | 08:50 PM
em1effekt's Avatar
where can i get one at?
Old Feb 7, 2011 | 05:51 AM
sohctodohc's Avatar
google it
Old Feb 7, 2011 | 03:30 PM
em1effekt's Avatar
got me an action clutch from the action clutch store for 192 well see how it goes..
Old Feb 7, 2011 | 03:57 PM
alexszst's Avatar
same thing happened to me on my 95 del sol bone stock, twice, and it happened on really rainy days, it wouldnt let me to do any gear when on, but perfectly shift when off,second time it happened I just gear first when off and I turn the igntion and it kinda pop up,issue was gone, couldnt find a reasonable explanation but maybe some water got inside the tranny, checked that out but couldnt find any and never got any type of problems with it besides that
Old Feb 8, 2011 | 06:49 PM
em1effekt's Avatar
replaced the clutch everything is back to normal =]
boostedrust
Jul 15, 2014 08:15 AM
ray.riddler92
May 4, 2011 01:00 PM
s13hero
Oct 13, 2010 02:33 PM
96 GSR-T
Jun 10, 2008 07:31 PM
diewX3
Feb 5, 2005 01:11 PM
