Seafoaming the Lude
Old Feb 2, 2011 | 11:30 PM
gceniceros209's Avatar
Default Seafoaming the Lude
Thought you guys might enjoy this vid of me using some seafoam on the car.
http://www.youtube.com/watch?v=2NtfRYf4JsI
Old Feb 3, 2011 | 05:16 AM
jnv255's Avatar
Default Re: Seafoaming the Lude
Haha. Looks like someone is spraying for Mosquitos
Old Feb 3, 2011 | 05:59 AM
1GPlusSH's Avatar
i've only had one car(89 civic) smoke that bad. congrats on the clean up
Old Feb 3, 2011 | 08:09 AM
mike541's Avatar
I'm a skeptic on that stuff. Let us know how much better(or worse) your car runs/performs now after the Seafoam. I've heard bad stories of this stuff. Seen someone use it on a Ranger and it ran exactly the same as before.
Old Feb 3, 2011 | 09:33 AM
1GPlusSH's Avatar
it jacks up the spark from your plugs. mine ran worse...slower and worse gas mileage. a friend told me to change my plugs, and the car ran MUCH better. my gas mileage went from 34 to 37mpg in my 89 hatch
Old Feb 3, 2011 | 09:50 AM
easy's Avatar
There are a lot of good guides on using the stuff that you can find. IF you follow any good guide they will usually start by tellin you it messes up the spark plugs and you shouldn't run it in the oil for more than 100 miles or so. Seafoam is a pretty harsh varnish solvent lol. I only seafoam when i know i have an oil change coming up and i throw new plugs in after i do the oil change. If used correctly it's very effective.
Old Feb 3, 2011 | 07:33 PM
Well my car car was running way shitty before and it ran less shitty afterwards. Changed the oil but i didnt know it jacks up the sparkplugsjust has put in some new spark plugs too
Old Feb 3, 2011 | 07:35 PM
in my car there was a small difference, car felt more smoother and maybe a bit more power. Id say its worth the $9 bucks
Old Feb 6, 2011 | 06:39 AM
rchid's Avatar
I'm planning on doing this sometime in the spring! glad i have a set of plugs laying around... where did you inject this in the engine?
Old Feb 6, 2011 | 07:12 AM
AndrewCjDuong's Avatar
I just put a bottle in my gas tank when I filled up. After doing that, the car ran very smooth and the idle didn't seem as loud and rough. I haven't done oil or anywhere else since that requires an oil change or spark plug change and all that and I recently did them all.
bkowa092
Acura TSX
Aug 3, 2017 09:13 AM
afnan
Jan 17, 2014 06:08 AM
92egcivicls
11
Oct 28, 2008 01:07 AM
EGhatchLSV
Jan 31, 2008 02:01 AM
98cwitr
Sep 29, 2003 07:23 AM
