clutch wont retract..
Old Feb 2, 2011 | 01:01 PM
blacklabel14's Avatar
Default clutch wont retract..
my clutch was working fine all day until last night when i turned on my car and my clutch felt weak and the point my clutch grabs was a centimeter instead of like an inch. this morning go to start my car and my clutch wont retract and i cant drive. wtf is wrong give tips please.
Old Feb 2, 2011 | 02:27 PM
94VTEC2TONE's Avatar
Default Re: clutch wont retract..
check the slave or master. if slave isnt working i doubt ull be able to get the clutch out of its position, because theres no pressure. lmk if that helps
Old Feb 2, 2011 | 06:09 PM
sayanything's Avatar
like you pressed the pedal down and it just sank to the floor and didnt come up? Yes thats going to mean either your master cylinders seals blew out, or theres a hole in your clutch line, or your slave went out. Another less likely thing is its possible your shift fork popped off the "pivot ball" in the trans housing.
Old Feb 2, 2011 | 08:48 PM
yea thanks man i just drained the slave and pumped the air out of it it working fine now.
98trooper
10
Aug 22, 2012 05:03 AM
blacklabel14
Feb 3, 2011 12:32 PM
mr. robot-o
Nov 9, 2008 06:27 AM
yellowEG
Mar 20, 2006 03:27 AM
geminis2k
Nov 20, 2003 11:33 AM
